11-03-2012, 11:43 AM   #1
k-x out of focus problem in viewfinder
I've recently started experiencing an issue with my 2.5 yr old K-X. It works greatly most of the time, but occasionally when I'm shooting up at something, the viewfinder goes out of focus. Auto focus still works fine, but what's seen in the eyepiece is out of focus. My wife's experienced it too, so it's not just my eyes. Holding the camera level plus a little shake temporarily resolves the problem. Anyone experience this or have any suggestions? Thanks!
11-03-2012, 11:45 AM   #2
JinDesu's Avatar
Did you try adjusting the diopter (little slider on top of the viewfinder)?
11-03-2012, 12:11 PM   #3
abmj's Avatar
Agree. Sounds like you have somehow nudged the diopter adjustment out of place. Try readjusting it. Don't focus on the distance, look at the setting numbers inside and across the bottom of the viewfinder and slide the adjustment bar until they are sharp.
11-03-2012, 12:14 PM   #4
Have you taken the lens off the camera and looked up into the pentaprism above the mirror? Is the focusing screen loose?
07-04-2019, 01:59 PM   #5
Any fixes?
Hi there, first post here.
This is my first Pentax, a K-x. My viewfinder also "lies" but it didn't bother me too much, since the autofocus lenses I have still work fine. But I just bought an older 28mm, manual focus and it's a pain to get it right, even with the beep.
My diopter goes all the way to the left but it's still not enough. Any advices?
Thank you,
07-04-2019, 05:05 PM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by AndreCArvalho Quote
Thank you,
Welcome to the Pentax Forums!
Possible causes:
  • Mirror out of alignment or not fully seated in the downward position. Usually this would also cause problems with the AF, so it unlikely in your case.
  • Fungus or grunge on the focus screen, mirrors, or eyepiece ocular
  • Eyesight requires more or different correction than is available through the diopter adjustment
If the last, one can add an additional correction diopter in place of the rubber eyepiece shade (See Pentax Forum Reviews | Correction Lens Adapter M). If an eyeglass user, wearing them while using the camera is another option.
07-06-2019, 07:48 AM   #7
Hi Steve,
I am not an eyeglass user. I looked into the correction lens adapter M and it makes sense, but my viewfinder is sharp behind the focused object; back focus. Will that rule out fungus or grunge?
I also found something here about shimming the viewfinder, would that be the case then?
Thanks,
Andre
focus, k-x, pentax help, viewfinder
Viewfinder / manual focus issues with K-x, versus K200D ChooseAName Troubleshooting and Beginner Help 5 09-15-2012 07:05 AM
K-5 Viewfinder and manual lenses focus problem PiotrKrochmal Pentax K-5 10 03-08-2012 03:54 PM
Pentax K-x Focus Mode Lever problem michaeljswaine Troubleshooting and Beginner Help 13 09-20-2011 11:53 AM
K-x Lense focus problem popellis Pentax DSLR Discussion 4 05-16-2011 11:40 AM
K-x viewfinder problem ?? eastbay Troubleshooting and Beginner Help 2 11-05-2010 09:01 PM
All times are GMT -7. The time now is 07:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
