Originally posted by rburgess ...cannot see out through the view finder...keep popping up in the view finder on the left side of it, and changing rapidly from 2 - 4 - 8 and so on...
Just guessing here...So the mirror is stuck in the up position and the cycle it sounds like it is stuck the state when it is to tell the system that the shot is finished and that is already reset?
Is the aperture stuck in the open (normal view) or stopped-down (taking picture with aperture set) position?
I would also hazard that if there is any decayed foam (a common problem) that it will need to be disassembled and cleaned.
