Originally posted by bluemarvin Thanks for that - I'm a little bit wary of modifying the camera as it works fine with my other lenses.
Obviously it is your choice. That said, shorting out the A pin on the body is easily, quickly and 100% reversible if you don't like it; further it will work just fine with any lens you can mount on your camera. The only difference is your camera will think all your lens are 'A' capable ... if a lens is 'A' capable, absolutely NO difference in performance. If the lens is a non-A, manual lens you use it exactly the same as you always did, only now you will see an aperture value and won't see "F - - -".
I have two Pentax A-series lenses, one F-series, three DA-series, a Sigma F-series equivalent lens. I frequently mount my A-50mm f/1.7 on a manual macro-converter giving me the equivalent of an M-series lens, and I have a Pentax K-mount bellows unit. Everything works perfectly, and I've never found a need to undo this modification. In another post in this forum I proved that I could even successfully do P-TTL flash photography using a borrowed M-50mm f/1.2 lens.
