11-12-2012, 01:40 PM   #1
alternative to K5 standard viewfinder cap
Hello,
I find the Pentax K5 viewfinder cap a pretty unhelpful piece of kit since so far as I can see you have to remove the viewfinder eye-cup and support frame to use it. Has anyone come up with a (homemade?) viewfinder cover solution which can be very quickly and simply dropped over the eye-piece when required for long exposures? I see electricians tape has been suggested previously but I am hoping somebody might have come up with a cleaner (more 'elegant') solution.
Thanks.
11-12-2012, 01:47 PM   #2
jatrax's Avatar
Try gaffer's tape rather than electrician's tape. It is available in wider widths and doesn't leave as much residue.
Other than that none of the caps I've seen work anyway except by sliding onto the view finder which requires removal of the rubber eye cup.
11-12-2012, 04:55 PM   #3
Canada_Rockies's Avatar
Hey, Mr. Ricoh/Pentax - where is my viewfinder blind??????? That's really the only good solution - but it means someone else's product.
11-12-2012, 09:16 PM   #4
Just1MoreDave's Avatar
I experimented with a piece of cardboard that tucks under the rubber on 3 sides. Plastic would be better but the cardboard seems to work OK. I tested it out with sun shining directly on the viewfinder and an IR filter in the lens. It works as well as the supplied piece. I'll use it until I find some matte black plastic.
11-13-2012, 02:01 AM   #5
neil's Avatar
I just leave gaffers tape stuck to my camera for this and many other purposes.
It may not be "elegant" but it's just a camera...
11-13-2012, 02:07 AM   #6
TOUGEFC's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Thats one of the features I really love on my D700 , very handy for long exposures
11-13-2012, 06:28 AM   #7
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
It doesn't solve the problem of requiring the removal of the eye-cup, but for over 30 years I have kept my viewfinder cap stitched like a button to the inside of my camera's neck strap. The cap has never been lost, and is always handy.
11-13-2012, 06:41 AM   #8
jac
I carry a cap with me all the time on my left hand. Works well up to about three feet from the camera - my thumb.
11-13-2012, 07:03 AM   #9
Fogel70's Avatar
I usually just put the lens cap on the eye-cup to block the light.
It seems to stay in place and block the light well enough in most cases, but I might start binging a rubber band to secure the cap better.
11-13-2012, 01:36 PM   #10
Thanks to all.
I have been fiddling about further with all sots of bits and pieces since I posted my query and have found that the rear lens cap from a Tamron lens fits over the rubber eye cup perfectly. It fits snugly onto and gently grips the rubber creating a secure cover.
11-15-2012, 08:17 AM   #11
abmj's Avatar
I sometimes just hang my hat over the viewfinder. For exposures faster than 1/60, my thumb works just fine.
camera, cap, k5, pentax help, photography, solution, viewfinder
K5 ME Viewfinder Cap fotogaffer Pentax K-5 13 01-06-2013 11:07 PM
K5 - Possible to increase viewfinder parameter display time? maomao Pentax K-5 2 08-17-2012 10:17 PM
DA 15mm Ltd. Alternative Lens Cap jcob Ask B&H Photo! 2 08-29-2011 04:50 PM
Alternative lens cap for the 70mm f/2.4 limited? jms698 Pentax SLR Lens Discussion 2 12-08-2010 05:43 PM
lost 31 lens cap - any alternative? nostatic Pentax SLR Lens Discussion 10 07-20-2009 07:16 PM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
