11-12-2012, 01:55 PM   #1
New Pentax and SLR owner, what lens?
Hello! I just got a K1000. Now I need a lens for it (and a K30 as I plan to get one.)
I need a good, not too expensive ($50-$?) lens (No clue what focal length ) that would preferably be weather sealed or resistant.
I shoot a lot of landscape, some general stuff (AKA oooo shiny,) I want to try street photography and everything else
BTW, my experience with SLR/DSLR cameras is... little to none.
11-12-2012, 02:02 PM   #2
boriscleto's Avatar
Pentax never made a weather sealed lens for a film body. In the film era the standard lens was the Nifty 50. Find yourself a K55/1.8, or M50/2. If you plan to use the lens with the K-30 look for an A50/2. The A50/1.7 is better than the A50/2 and is still less than $100. When you get the K-30 it will become a nice portrait lens. Then look for a 28mm or 35mm lens. These are closer to a 50mm equivalent on the K-30.
11-12-2012, 02:05 PM   #3
Docrwm's Avatar
Welcome Aboard.
Hard to go wrong with a 50mm to start on the K1000. There are lots of variants. Go to the Lens Review section and read -
Pentax Lenses - Pentax Lens Reviews & Lens Database
11-12-2012, 02:12 PM   #4
TenZ.NL's Avatar
If it`s for the K30, you might wanna buy a kit with the DA18-135 WR or if you wanna go cheap the DA18-55WR (and if you wanna go in the middle you can get both DA 18-55 and 50-200WR kitlenses)
I think the best option for you would the 18-135WR as it has good optics, it`s weathersealed and has a great range for all kinds of photograpy. You can try, fool around and develop your skills. As for the K1000 I second Boriscleto`s suggestion for a A50 1.7, you can use it on both cams.
11-12-2012, 02:34 PM   #5
QuoteOriginally posted by TenZ.NL Quote
Yeah, I've been eyeing that 18-135WR kit. How would an M50 1.7 compare to the A50 1.7? The M50 1.7 seems to be (from my searching) more common and a bit cheaper...
11-12-2012, 02:48 PM   #6
boriscleto's Avatar
QuoteOriginally posted by SpartanD63 Quote
The M50 is a good lens, optically it is the same as the A50, but it is a bit more difficult to use with a DSLR. On a DSLR you would be limited to manual mode and stop down metering. The A50 has electrical contacts to allow the DSLR to control the aperture. This allows the A series to use all exposure and flash modes of the DSLR like an autofocus lens. It just doesn't autofocus.
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
11-12-2012, 03:06 PM   #7
Considering that I wouldn't mind doing things manually I think I'll go with the cheaper M50 1.7.
11-13-2012, 05:34 AM   #8
It's an excellent choice for the K1000. With the K30 DSLR either go with one of the WR kit lenses of find a Pentax (or variant) A 28mm for a normal lens. You can use it for a wide on film.
11-13-2012, 06:23 AM   #9
Also just so you know, a PTTL flash used with a m series lens on a k-30 will always fire at full power. The a series lens will work as all of the newer lens with the flash.
11-13-2012, 08:00 AM   #10
The 50 1.7 lenses are fantastic, I had the m variant and loved it. I found it a really useful learning tool having to set aperture and soon got an 'eye' for what was needed so would adjust for the best aperture as I moved from shot to shot. Don't forget the green button for metering on the k30 though - set your ap, point, focus and compose, press green button to set shutter speed and fire the shutter.
11-13-2012, 08:13 AM   #11
normhead's Avatar
I went that road too and ignored auto-focus for 15 years. Then I turned 55 and my eyes went. Now I think auto-fous is the greatest thing since sliced bread.
11-13-2012, 10:20 AM   #12
DaveHolmes's Avatar
I think you need to consider a few things regarding what you actuall want your lenses to do and then re-visit your budgets a little but my intial thoughts are:
Landscape on film... M28mm
General stuff on film... M50mm (I'd hunt for an M50-1.4 or 1.7)
Both 28mm & 50mm will work with the K30 when you get one but 'A' versions of the lenses will work better... Neither offer WR but the K1000 isn't a WR-body... That said, one assumes that you'll be buying the K30 with a 'WR' 18-55mm kit lens which produces better images than kit-lenses from Canon or Nikon, so you're covered for 'weather' should it occur...
In terms of lens purchases I'd personally recommend you to be looking for:
a used 'F' or 'FA' 50mm 1.7 (or 1.4) and which can be used as a manual focus lens on the K1000 and an AF lens on the K30 ('normal' on film - short-tele-portrait on cropped sensor DSLR)
a used 'A' 28mm 2.8 (manual on both digital and film but offers aperture control for newer DSLR's) semi-wide and good for landscape on DSLR - Wide on film, good for landscape and street on film...
(this is where the budget takes a slight turn...)
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
DA35mm 2.4 as a 'normal' prime on the K30 (no aperture ring, so pretty useless on the K1000)
Macro is fun... a used DFA 100mm 2.8 (nonWRversion- has aperture ring and 'A' setting) film and digital compatible - Good for 'shiny things', flowers and candid portraits - as well as having a bit of reach...
Again... WR on the K30 should be covered by the 18-55WR kit (make sure you get the WR version)
Hope it helps...
Dave
11-14-2012, 12:14 AM   #13
arnold's Avatar
If you are concerned about cost, then go for the M50mm 2.0. It is only half a stop slower than the 1.7 and because there were so many made, costs less. At normal openings, I doubt you will see a quality difference from the more expensive lenses.
Here is a picture(s) wide open f2.0 hand held at 1/30 second, which is as bad a setting as you will likely use Quite acceptable results I think.
camera, lens, pentax help, photography
New Pentax Q owner and forum member qblade Welcomes and Introductions 2 10-28-2012 07:47 PM
(Almost) new K5 owner... but what lens? teamplayer Troubleshooting and Beginner Help 16 08-02-2011 12:46 PM
Hi everyone! I'm a K-x owner and new to SLR pentaximus Welcomes and Introductions 6 05-10-2011 07:48 AM
New to slr and pentax kayakgirl Welcomes and Introductions 2 02-04-2011 09:48 AM
PENTAX ANNOUNCES K-r DIGITAL SLR AND NEW 35MM LENS Adam Homepage & Official Pentax News 58 10-05-2010 11:35 AM
All times are GMT -7. The time now is 04:43 PM. | See also: NikonForums.com, part of our network of photo forums!
