11-14-2012, 06:49 AM   #1
K10d not recognising AF lens
I have a K10d and it has stopped recognizing AF lens when I put an AF lens in it asks to input the focal length for the shake control and when ive done that it says MF in the view finder .this is with all AF lens's including the Pentax kit lens's
11-14-2012, 07:06 AM   #2
ismaelg's Avatar
First step is to make sure the contacts are clean. Carefully clean the contacts in the body mount (and in the lens as well to make sure). You can use an eraser or a very fine grit sandpaper GENTLY. Check to see if any of the contacts look damaged or different.
Hope this helps.
Thanks,
11-14-2012, 07:27 AM   #3
JimJohnson's Avatar
In addition to cleaning the contact points, make sure all the screws for your body's mounting flange are snug. When mounting a lens, hold in the release button, turn the lens all the way into the mount, release the lens release button and turn the lens backwards in the mount until the lock clicks. If you still do not have full lens functioning, try slowly rocking the lens slightly clockwise / counter-clockwise and watch to see if you get a connection.
11-14-2012, 11:34 AM   #4
Well I combined the advice given by both ismaelg and Jim Johnson and it worked I honestly cant say which as I did them both at the same time. but I would like to thank both of you
11-14-2012, 12:27 PM   #5
ismaelg's Avatar
Since I wrote first I should get 51% of the credit!
Just kidding
Glad it worked!
Thanks,
af, k10d, lens, pentax help
K10d: AF-leds are not alligned in AF-frame jmbroekaert Troubleshooting and Beginner Help 5 10-17-2012 03:47 AM
k-5 not recognising 17 mm Pentax-M fisheye disco_owner Pentax K-5 5 04-22-2012 07:50 PM
K10D AF not locking Geekybiker Troubleshooting and Beginner Help 3 06-02-2011 01:57 PM
K10D not regonizing AF lens as AF Time Freeze Pentax SLR Lens Discussion 6 12-13-2007 11:30 AM
K10D: Center AF point not centered Photomy Pentax DSLR Discussion 14 02-10-2007 05:22 PM
All times are GMT -7. The time now is 11:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
