11-15-2012, 02:33 PM   #16
romansolar's Avatar
thanks!
so for example, when i will remove clip and mount adapters on m42 lenses, its safe to order even the cheapest ones? its safe because i will remove clip?
11-15-2012, 02:46 PM - 1 Like   #17
QuoteOriginally posted by romansolar Quote
thanks elliott, THoog
what do you mean with "square off the edges of the bayonet lugs" ?
On the adapters I bought the edges were rounded, this allowed the lugs to slip past the tabs in the camera. It might not happen on all bodies, but it happened on mine, so I ground them square.
This image shows the difference between an official adapter and a knock-off. The one on the right is the official one, notice how it has very square edges on the bayonet lugs. The one on the left has a sloped edge, this can allow the adapter to over rotate in the mount and get stuck.
PENTAX K100D  Photo
11-15-2012, 03:03 PM   #18
romansolar's Avatar
oh i see ! fantastic, thank you. i will be very careful, will do observation before installing
so far i cant find genuine adapter here within marketplace, but i found following stores, which one will be your choice?
M42 lenses on Pentax K
Pentax Manual Focus ADAPTER SCREW MOUNT TO K-MOUNT - KEH.com
11-15-2012, 04:06 PM - 1 Like   #19
jatrax's Avatar
Roman, you cannot always be sure with KEH because they do not always use exact photos. However, that one really does look like the genuine Pentax adapter and that is the correct price for it. The generic ones should be much cheaper.
My opinion is if you are just getting one, spend the extra money and get the Pentax one if you can find it. If you want to use an adapter on each lens then go with the generics as it is too expensive to buy Pentax ones for each lens.
Also here is an excellent article on using M42 lenses on Pentax DSLRs. You should read through before you try, it will save you some confusion: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/110658-using-ma...x-dslrs-f.html
11-15-2012, 06:08 PM   #20
OrchidJulie's Avatar
FWIW, B&H list the genuine Pentax adapter as "temporarily out of stock"
11-15-2012, 06:21 PM - 1 Like   #21
riff's Avatar
https://www.pentaxforums.com/forums/photographic-equipment-sale/202198-sale-1...-adapters.html
https://www.pentaxforums.com/forums/photographic-equipment-sale/203185-sale-t...2-k-adptr.html
https://www.pentaxforums.com/forums/photographic-equipment-sale/203108-sale-d...-b-w-film.html
These all seem to be still current/available. Hope that helps.
11-15-2012, 07:45 PM   #22
boriscleto's Avatar
QuoteOriginally posted by OrchidJulie Quote
And Pentaximaging.com doesn't list it at all.
The Pentax Japan web store has it for ~$55.
11-15-2012, 11:06 PM   #23
romansolar's Avatar
thank you all for valuable feedback!
i will check mentioned articles, links and marketplace
will come back with updates
adapter, adapters, lenses, m42, pentax, pentax help, pentax m42
Genuine Pentax Mount Adapter B or M42 To K adapter SANDY1977 Pentax Camera and Field Accessories 9 06-22-2013 02:41 PM
For Sale - Sold: Genuine Pentax PK-M42 adapter (Worldwide) matoqui Sold Items 2 04-03-2010 05:48 PM
For Sale - Sold: Genuine Pentax K > M42 adapter Squier Sold Items 2 08-02-2009 10:31 AM
All times are GMT -7. The time now is 01:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
