11-20-2012, 03:48 AM   #1
disco_owner's Avatar
Da18-135 Not Auto-Focussing
not sue if anyone can help , but when I place the Lens on the K5 and Turn the camera on , the camera is asking me to input the Focal Length of the lens ?? could it be a dirty /bad contacts on the lens , if I do select a FL and try and get a Focus in AF-S the lens will not under any circumstances Focus. any ideas??
11-20-2012, 04:00 AM - 1 Like   #2
Timd's Avatar
Whenever the camera has F--, it means that it has no communication with the lens. Either the lens is not properly mounted all the way or else the contacts are dirty. It will be pointless to select a focal length as the camera needs to read the lens to work as it is a DC lens with the focus motor onboard. Manually putting in focal length is only for manual focul lenses, AFAIK.
11-20-2012, 04:06 AM   #3
QuoteOriginally posted by Timd Quote
I tried cleaning the contacts on the Lens , but still the same , I also tried another Lens that I have and there is communication between it and the camera , so it must be the contacts on the Da18-135 Lens.
11-20-2012, 04:14 AM   #4
Timd's Avatar
I knew when I replied that there was the possibility that the problem was more severe. First clean the contacts; if that does not work, try it on another camera; if that does not work it needs to be fixed. Having said that, it is most likely to be the contacts. The 18-135 so far (apart from being slated by every lens reviewer) is a very reliable lens and does not suffer from Sudden Death Malaise (SDM!)
11-20-2012, 04:41 AM - 1 Like   #5
don't forget to clean the dc contacts, the 2 flat gold contacts and also on camera.
11-20-2012, 02:41 PM   #6
I placed a 2nd lens on the camera and AF works fine , the DC contacts on camera are clean , as i said earliet ,but regadless i went over all the contact again including the DC gold contacts , still no AF
11-20-2012, 10:35 PM - 1 Like   #7
Do you have a second camera body that has SDM contacts to try. There maybe a problem with the K-5 body contacts. There have been cases of the SDM contacts going out on a camera body, forcing the camera to use the screw drive on a SDM lens. I do not believe the 18-135 has the screw drive so if the body SDM contacts are bad, then no autofocus for this lens. Just something to check.
Rick
11-21-2012, 06:18 PM   #8
Something I must have overlooked , cleaning the Tiny Gold contacts on the camera but it appears I forgot this Important part gave the Tiny Gold contact on camera a clean as well last night and the and Lens is now Focussing.
Thanks for your Replies everyone!!!
11-22-2012, 10:06 AM   #9
Timd's Avatar
I love it when a problem is solved! (especially when there is no cost involved!)
11-22-2012, 01:08 PM   #10
I like this thread. Yet another proof of the 18-135 AF engine's reliability a little cleaning and it's all back to normal!
11-22-2012, 02:22 PM   #11
I had my doubts at first , was willing to put money on the SDM , the 18-135 has proven to be very realiable , it is my most used lens , specially for my surfs shots at sunrise.
11-27-2012, 01:31 AM   #12
The DA 18-135 is not an SDM lens. No * in the name, and the "DC" marking on the front means it's a different mechanism. Not SDM, not part of that whole problem and discussion.
11-27-2012, 01:33 AM   #13
I note I was mistaken about the * signifying SDM. Still, Pentax does not advertise the DA 18-135 as an SDM lens, but as a "DC" lens.
11-27-2012, 03:05 AM   #14
I thought I had initially Fixed the Problem by Cleaning the DC contacts on the camera. Nope The Problem has resurfaced. Still the same issue . Now it's has completely Failed. it's now Just a MF lens
12-01-2012, 05:05 PM   #15
QuoteOriginally posted by disco_owner Quote
Sad to hear that... well, it might just be the first case of a failed DC motor. Guess the best way is to send it back to have it fixed. As far as I remember from reading online though, is that the DC motor is, as the engineers call it, a "simple brushless DC motor" or something like that, which I hope indicates quick repair.
camera, focus, lens, pentax help
Selecting focussing area-Centre v Auto TylerD Troubleshooting and Beginner Help 24 06-12-2012 03:29 PM
Extreme Corner Performance Shootout - FA 43mm vs DA18-135 vs DA*50-135 chesebert Pentax SLR Lens Discussion 4 05-22-2012 09:38 AM
Landscape Flowers with DA18-135 Mr_Canuck Post Your Photos! 3 05-20-2011 01:12 PM
DA18-135 or DA18-250? jatrax Pentax SLR Lens Discussion 17 04-25-2011 08:41 PM
DA18-135 => Satisfied xGene Pentax SLR Lens Discussion 7 12-15-2010 02:17 PM
All times are GMT -7. The time now is 11:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
