11-24-2012, 05:05 PM   #1
K-5 Underexposure in Tv and Av
After working fine for nearly 2 years, my K-5 recently started consistently underexposing two or three stops in Tv and Av modes, regardless of which lens I use. Exposure with the Auto "Green" setting (which I never normally use) is perfect however, indicating that this is not a metering issue. Any suggestions what the problem might be?
11-24-2012, 05:30 PM   #2
GabrielFFontes's Avatar
Have you tried a factory reset?
11-24-2012, 05:30 PM   #3
Ex Finn.'s Avatar
I just had that happen at thanksgiving. It ended up being an operator error in my case, forgot that I had dialed in -2.7 EV compensation.
Something to check, just in case.
11-24-2012, 05:51 PM   #4
jatrax's Avatar
Check to make sure you do not have any exposure compensation dialed in. And if you are using flash check the flash exposure compensation as well.
Check a different lens just to rule out the lens.
11-24-2012, 06:20 PM   #5
calsan's Avatar
Is the meter mode in spot, center or matrix?
11-25-2012, 12:31 AM   #6
Thanks for your suggestions. The underexposure occurs with three different lenses, I have checked that there is zero EV compensation set and I am not using flash. The metering mode is set to matrix but I have not changed that for several months (long before the problem started). I have not tried a "factory reset" - does that mean downloading and installing the latest firmware?
11-25-2012, 04:13 AM   #7
Fogel70's Avatar
QuoteOriginally posted by Robinvic Quote
Using green mode will set most settings to the "green" default value. Many of the functions in the camera will be disabled, and all custom setting will be disabled.
FI, exposure compensation is not available in green mode, and metering will be multi-segment only. So if the camera is set for any other metering mode, and if you have set exposure compensation, it will only show when you use Tv or Av mode.
11-25-2012, 08:45 AM   #8
Ex Finn.'s Avatar
No, it just resets everything back to "normal". You find it in Custom menu, page 4, last item at the bottom.
11-25-2012, 08:50 AM   #9
You go around the menu and reset every setting.
Custom settings, picture settings, blah blah blah...
Go around the menus and every "reset" thing there is, just click it...then turn the camera off, remove the battery, let it sit like that for a couple of seconds and put it back in and turn on.
11-25-2012, 10:15 PM   #10
QuoteOriginally posted by Ex Finn. Quote
Thank you, I tried that but it did not help (there was only one small item in the Custom menu that was not already on the "1" default setting). However I will keep looking at the other menus in case there is some other setting that I have accidentally changed, and re-set them as necessary.
11-27-2012, 04:58 PM   #11
Success finally!
(with thanks to Rio and Maryland!). As previously mentioned, resetting the Custom menu did not help and I checked all my other settings individually without getting anywhere. However, as soon as I hit "Reset" on Set-up menu 3 the problem went away - and even when I reintroduced all my old settings as I had noted them, everything still looks good. So I guess the key is to quit treating it logically like a camera and remember that it's basically a computer (ie: if in doubt, re-boot!). Another inch up the learning curve . . .
11-27-2012, 06:38 PM   #12
Glad i could help =)
Yes, don't try to understand why doing that factory reset helps at all, and why rebooting and/or closing an opening again helps...it just works
av, k-5, pentax help, tv
Are Tv and Av obsolete on the K-5? Yeti Pentax K-5 & K-5 II 9 03-31-2012 04:32 PM
DOF preview with M lens and Av/Tv mode atekant Pentax K-5 & K-5 II 14 02-23-2012 07:58 PM
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 & K-5 II 3 09-30-2011 09:03 AM
Metering in Av or Tv mode sany Troubleshooting and Beginner Help 23 04-27-2011 09:31 PM
Different exposure TV and AV mode Sekul Pentax K-r 4 12-26-2010 04:09 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
