11-26-2012, 03:21 AM   #1
k20d mirrow lock up timer function
Dear all,
I hoped I have place this message at the right locations, there are no place for the k20d in this forum.
I have a Pentax k20d and I would like to use it for astrophotography, but for that to work, I need the whole photo setup (ie telescope and camera assemble) to be very still. I know the k20d have a 2 second mirror lock up function(this means the mirror lock up into place and wait for 2 seconds before taking the photo.). There is also a 10 second wait function, but in this mode, the mirror move at the 10 seconds mark which results in shaking the whole assembly and then takes the picture.
My question is, is/are there ways of increasing the waiting time between mirror lock-up and the processor taking the picture?
Any suggestion or hints will be greatly appreciated.
sincerely.
11-26-2012, 03:38 AM   #2
Fogel70's Avatar
You can try using live-view.
11-26-2012, 07:51 AM   #3
audiobomber's Avatar
QuoteOriginally posted by nuk20d Quote
You can get one extra second if you use the remote with 3s timer. Other than that, nothing I could find.
QuoteOriginally posted by Fogel70 Quote
The mirror flops in live-view with the K20D.
11-26-2012, 04:23 PM   #4
dms
An old standard device. Trip the shutter with a long exposure time, with a card (your hat, ...) almost touching the lens--then take away the card and expose for desired duration.
11-26-2012, 05:56 PM   #5
zekewhipper's Avatar
Don't bother with liveview, as it is terrible. Audiobomber's suggestion of using the remote timer is the best route I know of.
12-01-2012, 04:42 AM   #6
thank you to all for your input.
Dear all contributors,
I would like to thank you for your imput into my issue. I have red about the hat in front of the lense trick, but I must have forgot then it.
this seems to be the simplest solution to my problem. Now all I have to do is make a blocking screen.
thank you .
Sincerely.
12-01-2012, 07:08 AM   #7
Can you please explain why you need more time with the mirror up for astrophotography? Is it because the assembly is still shaking after two seconds?
12-01-2012, 02:14 PM   #8
dms
In the scenario you ask about typically your shutter speed will be many seconds, so holding a card close to but not touching the lens front will work fine--the fact that a very little light enters is insignificant. The point being you actually don't want it touching as you then cause vibrations in the telescope when removing the card.
Just trip the shutter, count to 10 maybe, and then pull the card away--and set exposure time to include the extra time the card blocked the lens. Often in this situation (anyway if using bulb setting) you will continue to count and use that as your timer.
function, k20d, mirror, pentax help, picture
Mirror lock-up gorski Pentax K-30 & K-50 3 07-23-2012 04:04 PM
K-5 lock-up Lemonhead Pentax K-5 12 07-04-2012 01:30 PM
Weak Pop-Up Flash Lock? Tomzee93 Pentax K-5 2 12-31-2011 04:21 PM
Mirror Lock up function K10 vs K20 Hornet Pentax DSLR Discussion 4 11-20-2008 04:53 AM
Temporary Lock function Kaimarx Site Suggestions and Help 2 01-16-2008 03:07 PM
All times are GMT -7. The time now is 08:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
