When you do a lens adjustment you have a choice of applying the adjustment to all lenses or the mounted lens only. (This is the case with the K-7, I'm assuming it's the same with the K-5). Applying to the mounted lens only requires the lens to have a lens ID. So your camera will remember the setting for your 60-250. I don't own any third party lenses so I don't know if they have lens IDs. If not, you would have to set the adjustment each time you mount the lens. But if they do have lens IDs then like the 60-250 the camera will remember the adjustment.
But you should only do adjustments if needed. Out of all my lenses, only one needed an adjustment.
