Originally posted by TomB_tx This is an area that digital has changed a LOT. Reportage and publication work used to involve shooting, then dropping your film with the photo editor, and the publishing department handled the rest. They wanted shooters who could get usable shots that needed a minimum of work to print, so the editors wanted to see contact sheets of negatives and sets of Kodachrome slides to see how well you operated a camera and composed shots. We learned darkroom work more as a way to learn to shoot better than as and end in itself. I still prefer to try to capture the shot as if it were on Kodachrome.
Now with cameras largely taking care of exposure and focus the emphasis is shifted more to creating the imagined image, based on the capture as a starting point. Everyone can capture shots today, and everyone has a camera of some type with them all the time. The need for a staff of shooters has disappeared. There's a lot more imagination and artistry in image making today, using different skills and expectations.
Even with Kodachrome you had a little latitude. Even in developing it. Changing your top and bottom exposures would yield different results in the final slide.
Quote: I agree; people often want to know what can come right out of the camera.
If you want to see that look at an unprocessed Raw. That's right out of the camera with no processing so to speak.
I started developing my own film in 6th grade.Had my own darkroom in 7th. Everything that was done had some post to it.
Whether it was the paper I chose. The development times I used. The developer I used. The actual enlarger and lenses I chose all affected the final print. Dodging. burning, Composites (We had "layers" way before photoshop. Just had to be willing to hand cut them. And when you screwed up you started over.) I use to spend days cutting masks to get a photo that you couldn't tell was a fake. But I got pretty good at it and even was called as an expert witness as a teen a few times. All that said I shoot raw + jpeg. I like having a fairly decent shot to just print and put in an album. Not every picture needs to be "perfect" It's taken me a long time to realize that.
There's a pretty good chance that you've never seen a shot "right out of the camera" since so many things will change its appearance. Including the light it's viewed under.
Here's one for you. I do PP for a few different photogs. Try coming up with different "styles". It's not easy.
