The scale is 10x smaller, so you have to multiply the value by 10.
If you want a +10 adjustment, you need to input +100um in debug mode.
The scale is 10x smaller, therefore the value has to be 10x bigger to match. (i'm not sure if i'm saying this the right way..if i'm not, forgive me, English is not my main language)
No. If you put the debug adjustment to +1 while you have +8 set in your menu, then you'll have a +8,1 adjustment.
To get to +18 you need to input +8 in camera "AF Fine adjusment" menu and +100 in debug.
