12-09-2012, 07:35 AM   #1
Jean Poitiers's Avatar
Servicing a Helios 44M ... any advice
Bonjour,
Just picked up (another) thrift store 44M with good optics (for 3) , but the focus ring sticks hard ... time for some servicing.
I have re-lubed other M42 type lenses, but not this one. Has anyone pulled apart one of these? Any DIY threads out there to be seen?
Thanks in advance for any input - Jean le Frog
12-09-2012, 07:37 AM   #2
ducdao's Avatar
Can you post a the pictures of the lens? There are several versions of the same lens.
12-09-2012, 07:52 AM   #3
QuoteOriginally posted by ducdao Quote
Bonjour ducdoa ... It looks just like my other "good" 44M, which is pictured below ... Salut, John
01-26-2013, 10:45 AM   #4
I have the same lens and same problem. Google puled up a you tube video from a guy in Poland of the dissasembly so I am going to try to use that as a guide.
How have you got on?
01-26-2013, 11:55 AM   #5
QuoteOriginally posted by marcusBMG Quote
Thanks for your message about the you tube video ... I'll try to find that one.
I have not started a repair or anything, because things are too busy at the moment - J
02-05-2013, 05:33 PM - 1 Like   #6
QuoteOriginally posted by Jean Poitiers Quote
la vie c'est trop occupe...
Alors mon ami
the u tube video I mentioned is
Na warsztacie: Obiektyw Helios 44M 58mm/2 (demonta? / disassembly Helios 44M) - YouTube
Its of interest but a pertinent comment posted is that it is not clear how or if he has sorted out correct/infinity focus.
This posting on mflenses is specifically useful:
Help me get my Helios 44M back together!
and I paid attention to it in fixing the stiff focus on mine. However I didn't go as far as he does in disasembly. The easy stuff:
1. take off the mount, aperture sleeve (attention - 2 ball bearings), aperture coupling (lifts out)
2. take off the name ring and housing (3 screws) at the front
3. take off the focus sleeve (3 x set screws those are the itty bitty slotted ones that screw through a barrel to engage with a sleeve or inner barrel and have a point on the end) and depth of field sleeve (same).
None of this changes focus settings. sleeves can only go back in one position.
At this point the helicoid is partially visible. The next stage is the passage clef..
but I just wiped the exposed helicoid with a tissue moistened with WD40 that has eased matters and I'll see how it goes before going for the full monty
I intend to write this up
Another u tube posting I can mention is
however the helos 44-2 is in fact mechanically quite different.
02-06-2013, 01:31 AM   #7
Thanks marcusBMG ... thanks a lot !
44m, helios 44m, pentax help
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
Why is Helios 44m-4 more expensive than 44m? iNicole Pentax SLR Lens Discussion 3 08-07-2012 07:48 PM
Can I use a Helios 44m on K-r? Eric_the_fish Pentax K-r 11 12-08-2011 03:02 AM
Nature Just a few autumnal ones with the Helios 44M Rense Post Your Photos! 5 11-07-2011 10:01 PM
Helios 44M-4 vs 44M teartear Pentax SLR Lens Discussion 27 08-24-2011 03:25 AM
All times are GMT -7. The time now is 05:11 AM. | See also: NikonForums.com, part of our network of photo forums!
