Originally posted by theoicarry How many shots are you getting with the battery?
Teho
I really haven't kept track, I know I went to an event shortly after I got it and shot at least 258 raw pics and 34 videos, over 10 GB data and did change the battery right before the end. But the battery use depends a lot on if you are using live view, flash, long exposures, etc. I have noticed one thing that will drain the battery. If I plug the camera into the computer to download photos, and forget to turn the camera off, it will drain in a couple of hours or less, even though it shuts down. I don't expect quite as much battery life as I had with the K20D because the battery is smaller and the display bigger. But it is still good and I can't complain. Hopefully that Pentax rep is correct.
