Originally posted by VisualDarkness Do you have the setting for aperture ring permitted? If not the camera won't shoot if it doesn't get the aperture from the lens.
Thank you, Visual Darness...
Please pardon these simplistic questions... I really have tried to dig through the manual.
I went into custom menu and programmed both ways (Aperture Permitted and Aperture Prohibited). (When I changed to PERMITTED, the usual green display of the number 1 went to number 2, but it was in white, not green.... Is that correct?)
Anyway, there was no difference in the results; i tried both modes on 2 different Pentax lenses that have aperture rings. On MANUAL, moving the aperture ring on the lens to various settings only produces a flashing F and stops do not appear....
However, I found that by moving the rear dial in Av mode, I could change the F stops OK. This was in Manual. But why doesn't moving the aperture ring on the lens produce the same result?
