12-29-2012, 11:21 PM   #1
Tackling Lateral Chromatic Aberration
Hi guys, lately I have gotten some great shots that I fear are being ruined by lateral chromatic aberrations. I need help understanding it, and how to rectify the situation!
I have a K-7 and the kit lenses which I got primarily for outdoor photos because they're nice and weather sealed. I've taken many pictures with the18-55 WR and am still trying to figure out the best aperture to shoot with to reduce aberrations.
Is the in-camera removal of any use? Haven't used it much, but my initial impressions are that it doesn't work so well.
Can Lightroom do it? I have lightroom 4 but can't find the 18-55mm WR lens profile in it.
Does HDR always make aberrations more noticeable? I like taking HDR photos, but then it seems to make the purple fringing / weird outlines worse. Any help with this?
Is it just that this is a cheap lens? Other than the lateral chromatic aberrations, I love this lens! It fits the bill perfectly because it is inexpensive so I don't have to worry as bad if it gets destroyed on a hike, and it gets pretty sharp (I think) around F7.
Here is a link to an example of what I thought was a good photo somewhat ruined by fringing / lateral chromatic aberrations!
I haven't posted on PF for a long time, but I appreciate the input from you guys when I need it. Thank you!
12-30-2012, 12:24 AM   #2
Singe large parts of the image are distorted, it may be hard to correct. You should try sharpening it and applying lens correction profiles, but honestly, the only solution is to either use a better lens or get more megapixels (or scale the final product). Sounds like you need the Pentax 15mm or 21mm limited!
12-30-2012, 12:28 AM   #3
Use the chromatic aberration checkbox in LR4, and also the manual fringing controls. Get rid of the fringing in the individual images first (don't HDR in camera) and then do further processing -- your fringing is being made even worse by the processing. (Over-processing, I think, but that's another subject.)
12-30-2012, 03:29 AM   #4
I assume you shoot JPG? I don't think LR does lens correction for JPGs, however, LR4 got a very good manual correction tool that you can use to correct CA, it cleans up CA for my old lens pretty well.
12-30-2012, 05:55 AM   #5
Lowell Goudge's Avatar
There are lots of ways to deal with this issue.
The Pentax photo lab has a lateral CA correction tool. Most photo editors have one. There is also a plug in which should work in Lightroom called PT Lens which can do the same job.
I use PT lens with Corel paint shop pro X5. It works well. These tools rescale the color layers and then realign the layers to also improve edge sharpness.
I have not tried in body correction, which does the same thing, because it slows image writing
How about posting an example
12-30-2012, 07:10 PM   #6
Wow, I had never seen the Chromatic aberration box in LR4! It helps a lot! Sure it's not as good as a 15mm limited, but checking the box is within my budget right now.
12-30-2012, 07:16 PM   #7
QuoteOriginally posted by elpolodiablo Quote
I always shoot RAW for HDR. Also, I had never seen Pentax lenses be an option in Lightroom (the dropdown menu shows everybody but them), but I found if you just check the box "Enable Profile Corrections" then click "Custom" it brings up the lens automatically. This is going to change my world.
aberrations, camera, guys, hdr, help, lens, lightroom, pentax help, photography, photos, wr
Chromatic Aberration!? and what to do with it marcusBMG Digital Processing, Software, and Printing 15 12-26-2012 02:50 PM
Linux chromatic aberration correction russell2pi Digital Processing, Software, and Printing 8 09-10-2012 05:45 AM
Is this chromatic aberration normal for DA 14mm photomission Pentax SLR Lens Discussion 18 07-12-2012 10:12 PM
Correcting lateral chromatic aberration Todd Adamson Pentax SLR Lens Discussion 6 12-21-2010 03:36 PM
Purple Fringing vs. Chromatic Aberration dasuhu Troubleshooting and Beginner Help 9 08-07-2010 02:05 PM
All times are GMT -7. The time now is 08:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
