12-30-2012, 07:08 PM   #1
K-5 and Lightroom
Hi, I recently purchased a K-5 and Lightroom 4. In the little bit that that I've used lightroom I've found (as others have reported here) that the Adobe Standard Camera Profile results in colors that are somewhat dull compared to the K-5/Silkypix processing and that the "imbedded" profile available with DNG files seems to come closer to the K-5 processing. So a few questions:
- Are there any drawbacks using the DNG format vs PEF?
- Since the DNG is an unprocessed file, what's in this imbedded profile Lightroom pulls from the DNG? Does the camera add processing hints to the DNG?
- Finally, Does it make sense to use the lens and shadow correction in the camera or is it best left to lightroom?
Thanks,
Tim
12-30-2012, 10:19 PM   #2
QuoteOriginally posted by timfrommn Quote
Thanks,
Tim
There is no practical difference between DNG and PEF other than filesize, but you still can't expect the raw processor's auto mode to make perfect adjustments every time. You will have to step in and adjust things manually more often than not.
In-camera shadow/highlight correction will yield a different result since it cranks up the ISO, but I personally stick to just the raw file and make sure the exposure is kosher to begin with.
camera, dng, k-5, lightroom, pentax help, photography, profile
Lightroom and Photoshop for K-5 .PEF files? BONSTA Pentax K-5 28 09-02-2013 01:40 PM
Suggestion K-5 forum renamed to K-5, K-5 II, and K-5 IIs? Buschmaster Site Suggestions and Help 2 10-16-2012 02:17 PM
K-5 and Lightroom profiles Jool Pentax K-5 13 10-01-2011 05:43 AM
Pentax k-5 Lightroom Settings magnosantos Pentax K-5 3 06-22-2011 04:10 PM
K-r and K-5 with Lightroom 2 NonEntity Digital Processing, Software, and Printing 21 02-01-2011 12:31 PM
All times are GMT -7. The time now is 06:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
