01-02-2013, 01:17 PM   #1
What is this? (Dust on sensor?)
Hi all. Please see attached photo from yesterday, shooting outside in very bright conditions - no artistic merit in this shot, but it shows the problem most clearly. This spot is still visible today after asking the camera to do some "Dust Removal" a couple of times, and also with a different lens attached. The spot gets more diffuse at more open apertures (say F/2.8 or 3.5) and is more clearly formed around F/8 and onward. (I can even see it on the LCD if I look carefully.) The camera is an almost new K-01 with latest firmware.
Do I already need to learn how to clean the sensor or is there possibly a problem/malfunction with the sensor? Or am I missing anything?
Thanks for any help/suggestions.
PENTAX K-01  Photo
01-02-2013, 01:22 PM   #2
lammie200's Avatar
I would say that it is mostly likely, if undoubtedly, dust. A while ago there was a great debate about the merits of blowing dust off with a Rocket Blower, or some other methods. You might want to do a search if you are bored. If you aren't bored, get a Rocket Blower and blow it off.
01-02-2013, 01:23 PM   #3
Looks like a piece of hair or something like that stuck on your sensor. It can be blown away.
01-02-2013, 01:25 PM   #4
mrNewt's Avatar
Just don't use your mouth to blow it off ... it will get worse .
Use a Rocket Blower or something similar .
And just for the hell of it, check the back of the lenses as well ...
01-02-2013, 01:34 PM   #5
Jean Poitiers's Avatar
Agreed - get a blower ... well worth it for the minimal investment ... use mine a lot. J
01-02-2013, 02:01 PM   #6
lguckert79's Avatar
yes use a blower i use mine at least once every 2 weeks on my k10d
01-02-2013, 02:50 PM   #7
Thanks
Thanks all. I don't have a blower yet, so I'll have to wait at least a day to get one, but after reading up on this a little, I went ahead and had a look at the sensor (remove lens, turn camera on, put it in sensor cleaning mode, have a look under a bright light) and I can clearly see something on there with the appropriate shape and in the appropriate spot (ie vertically flipped wrt to where the spot is in the image). Feels odd for this P&S upgrader to be looking right at the camera's sensor! Anyhow, I'll try with the blower first, then if that doesn't work, I guess I'll need to get a cleaning kit...
01-02-2013, 06:21 PM   #8
QuoteOriginally posted by Doundounba Quote
OK I will complicate a simple problem. Blowing is not effective on all spots (it should be with yours). Now that your looking. Take a read of all you can if you have the time. Take a look at Pentax Image Sensor Cleaning Kit, O-ICK1, Any brand of wet swabs. And I would recommend taking a read of VisibleDust web site and their products. They are the only company that make tools to clean any area of your camera. Keep this in mind for any future issues. VisibleDust makes wet and dry tools to clean your focus-screen, mirror/box. Even reach down and clean the AF lens with VisibleDusts curved brush. Most folks get along just fine with a blower. But it all depends on your environment and you. I can't just use a blower... just some FWIW.
But that what you show, no problem, normal, easy. Relax and enjoy SLR photography. There are many IMOs. Do what works for you. How do you know what works; time.
01-03-2013, 08:13 AM   #9
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
While likely dust on the sensor; while the lens is unmounted, also check the rear element.
01-04-2013, 07:57 PM   #10
OK, I purchased a blower tonight and... success! My sensor looks immaculately clean again. Thanks to all.
01-05-2013, 03:00 AM   #11
Good to hear ... congrats - J
01-05-2013, 03:08 AM   #12
Now purchase two more. You can't purchase one too many of those. Always useful to have one at home, one in the main pack and one in the back-up pack (i.e. if you have a back-up pack).
01-05-2013, 09:07 AM   #13
JimJohnson's Avatar
QuoteOriginally posted by voyager13 Quote
The big rocket Giottos stays with my gear at home. I purchased the smaller version of the Giottos blower without the rocket fins for my field pack. I remove the nozzle and insert it backwards to save space. Because it can easily compress in this configuration, it doubles as a shock absorber. I also keep a Lens Pen in my field bag.
01-05-2013, 09:13 AM   #14
QuoteOriginally posted by JimJohnson Quote
insert it backwards
Now that's a neat idea for a shock absorber
01-25-2013, 08:14 PM   #15
KB1SFVE3's Avatar
My hunch is that it's dust on your sensor.
And it looks like a rather large "hairy" piece of dust at that!
I also know a lot of folks here have recommended using a "Rocket Blower" to remove dust. However, I've found that approach simply moves the dust around inside the camera...and it may even blow dust into other places where it will be even MORE of an irritant...such as between a pentaprism and a focusing screen.
Over the years, I've tried many different so-called "solutions" for sensor dust removal and I think I have finally found one that works simply, quickly and effectively.
These days, I regularly remove dust from the sensors on all of my DSLRs using a thing called an Arctic Butterfly. Indeed, I've learned that, compared to the cost (and hassle) of having a camera shop do it, along with my penchant for swapping lenses all the time...the thing paid for itself the very first time I used it.
Unfortunately, as the rubber seals, gaskets and pieces of foam in these cameras age over time (along with the continual movement of air in and out of the camera with the use of zoom lenses) one can't help but have such stuff sucked into (or around) inside your camera, some of which eventually winds up on the sensor. I have also learned that this can happen even if you don't swap lenses all the time. For example, some dust showed up on the sensor of my brand new K-20 a while back even though up to that point I had never swapped lenses on it!
The bottom line here is that dust WILL get onto your camera's sensor sooner or later....regardless of how careful you are to keep it out.
I've also learned that the "sensor shake" feature on K-20D-era (and earlier) Pentax cameras may have been a great Madison Avenue selling point at the time, but is nigh on useless in practice. It simply doesn't work.
However, I now understand the newer Pentax cameras have an "ultrasonic" feature that shakes the dust off the sensor....and into a "catcher" of some sort. Call me a purist, but, just with the use of Rocket Blowers, this feature still only moves the dust around inside the camera rather than getting it out completely!
The Butterfly thingie works by spinning the inserted brush (which gives it a static charge) outside the camera. Then, once you've removed the lens and activated your "mirror up" feature on the camera, as you pass the brush (gently) over the sensor and the dust is sucked up onto the brush because it's statically charged. You then spin the brush again (outside the camera). This gets rid of the collected dust off the brush as well as re-charging it. You can then repeat the process if you like. Usually, one or two spins and passes over the sensor are enough to get rid of the pesky stuff.
And, if you have any concerns about scratching your sensor with the brush...relax. The Arctic Butterfly brush is specifically manufactured for sensor cleaning and contains some VERY fine bristles, so there should be no worries about scratching your sensor with it.
The Arctic Butterfly is marketed by an outfit out in Canmore, Alberta, but is available in the USA via Amazon and most of the big US camera dealers such as B&H as well as Adorama. The outfit's name is Visible Dust. I also own their lighted Sensor Loupe that lights up the sensor to show you exactly where the dust is on the sensor before you clean it (and to show you when it's gone!).
Visible Dust also markets a line of liquid cleaners specifically manufactured to get rid of such things as oil smears and other more stubborn "goop" from sensors. But, as I said, most the time, it's simply a dust issue and it usually takes less than a minute or two (with a few swipes of my Arctic Butterfly) to get rid of it.
Here's a link to a You Tube Video that shows you how the Arctic Butterfly works:
Now if this all sounds like a paid advertisement for Visible Dust...it isn't. I'm simply a very satisfied user of their products. And while their products may appear a bit pricey, the Arctic Butterfly is a really great product that is simple to use, VERY effective and a whole lot less costly over time than having a camera shop continually remove the dust for you.
Needless to say, my Arctic Butterfly and Sensor Loupe now occupy a special place in my camera bag and go with me everywhere I go.
camera, pentax help, sensor, spot
Is this dust on the sensor? How do I remove? jeztastic Troubleshooting and Beginner Help 23 12-20-2011 08:49 PM
Help! Is this stain or dust on the sensor? catastrophe Pentax K-5 & K-5 II 5 10-12-2011 06:20 PM
Is this dust on the sensor? bessa66 Troubleshooting and Beginner Help 6 09-14-2011 03:25 PM
Is this dust in lens or on sensor? unclephil12 Pentax DSLR Discussion 3 07-07-2009 07:35 AM
Is this dust on my K200D sensor? mrpackerguy Pentax DSLR Discussion 11 10-21-2008 04:48 PM
All times are GMT -7. The time now is 01:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
