01-03-2013, 04:39 AM   #1
romansolar's Avatar
Help! K5 wont shoot with build in flesh opened
Hello dear pentaxians
my friend have problem with k5, since few days, her K5 wont respond when flesh is opened. When she closed build in flesh, k5 is working.
any advice? please help
she already tried to reset to factory settings, nothing changed
thanks
01-03-2013, 05:22 AM   #2
It won't operate unless the flash is charged. Is it?
It is possible to change this in the Custom menu.
01-03-2013, 06:15 AM   #3
romansolar's Avatar
thx John for reply
we can change option in menu, so camera will fire without flash, but this wont solve our issue. we would like to use internal flash. I think camera need to send for service repair
01-03-2013, 06:18 AM   #4
LeDave's Avatar
Maybe the flash has a defect and it cannot charge? Hopefully you guys figure something out!
01-03-2013, 06:21 AM   #5
romansolar's Avatar
thanks for reply. Hard to say, i will let you know.
Any other ideas?
01-03-2013, 07:04 AM   #6
LeDave's Avatar
I would say check the battery's charge. Also remove the battery and re-insert them and see if it works. That's all the ideas I have left =(
01-03-2013, 07:14 AM   #7
mrNewt's Avatar
Check battery / replace battery.
If is still doing that than I guess something went wrong with how the built-in flash is charging.
In that case, I strongly recommend to take it to a professional (unless you know what you are doing) or return it to Pentax if still under warranty and let them figure it out what went wrong.
01-03-2013, 09:04 AM   #8
romansolar's Avatar
good idea with battery, will try it. if it wont help, we will send it forward
thanks!
01-03-2013, 02:41 PM   #9
im having the same pop-up flash issue w/ mine. my shutter actuations is around 3k. when I use a (yongnuo) bounce flash it fires the bounce flash just fine, works as intended. I remove the camera battery ouf of the k-5 when not in use so i dont think its the battery.
01-03-2013, 02:46 PM   #10
Will the flash fire at all? If not, probably broken. My K-5 did the same thing -- camera worked fine with flash closed, but open no flash, no nothing. Had to send to for warranty repair, now works fine.
01-03-2013, 02:55 PM   #11
- im not sure if the above is for me. the camera works just fine if not using the pop-up flash. if the pop-up flash is open, it wont fire the flash but it will fire the flash using a bounce flash. im not sure if i should send it for repair since using a bounce flash is way better than the pop-up anyways. dilemma! dilemma!
01-03-2013, 03:08 PM   #12
Stone G.'s Avatar
I am afraid that vonBaloney is right. The same thing happened to me with my old *ist DL: The discharge tube in the built-in flash went "poof" one day and from thereonafter the battery icon would show "no charge" with the flash raised as soon as I pressed the shutter button, and the shutter wouldn't work until I lowered the flash again. I would definitely send my K-5 in for professional repair in a situation like this.
01-03-2013, 03:38 PM   #13
romansolar's Avatar
thx people, k5 was already sent for repair
flesh, k5, pentax help
Help needed with Catwalk shoot Zafar Iqbal Flashes, Lighting, and Studio 21 11-13-2012 05:10 PM
Pentax Q in the Flesh Kenn100D Pentax Q 1308 09-14-2011 01:39 AM
PLease help me with settings for a shoot! lovemehate Troubleshooting and Beginner Help 23 09-06-2011 09:33 PM
Help! Black spot wont go away! insulinguy Pentax DSLR Discussion 16 08-02-2011 03:46 PM
Spotmatic motordrive...in the flesh! pickles Pentax Film SLR Discussion 8 08-09-2010 01:00 PM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
