01-03-2013, 01:25 PM   #1
Loupe sensor cleaning with opteka ssc 85
I just came across this loupe sensor magnifier for cleaning made by Opteka.
Opteka SSC-85 10x CCD/CMOS Dust Illuminating LED Sensor Loupe
Has anyone used it or have any thoughts on this. It sells fro about $40.00. It seems to resemble the Visible Dust BriteVue Sensor Loupe 7X that retails for about $100. I was going to buy the Dot Line DL-SLCK SensorVu Loupe.
Dot Line DL-SL DLC Sensor-Vu Loupe (5x) DL-SL B&H Photo Video
between the different items I mentioned I think the Opteka will be one that will not bust my pocket and be better than the dot line which seems to be flimsy and does not have to many good reviews.
Any thought welcomed
JC
01-03-2013, 02:16 PM   #2
Khashoggi's Avatar
Never heard of it. But it's a bit un clear to me how it works except for putting it on the mount of your lens. I think I start using google on the item myself as I've got no clue how the item should work.
01-03-2013, 02:36 PM   #3
blackcloudbrew's Avatar
While I have the full cleaning kit from Delkin the singular most useful item in the kit is this:
Amazon.com: Delkin Devices DDSS-SINGLE SensorScope Includes bag: Camera & Photo
Having a lighted loupe is a very big plus when doing sensor cleaning. So it seems to me that the one your looking at should be just fine.
01-03-2013, 02:38 PM   #4
From what i have seen it works just like the Visible Dust BriteVue Sensor Loupe 7X it just to look to see if you have dust on the sensor. the only difference i see with the two is that the Opetka is 10x magnifying while the visible dust Britevue is only 7x. Both have 6 leds.
01-04-2013, 12:11 AM   #5
Thanks blackcloudbrew, and Khashoggi for you input. I think that the
Opteka SSC-85 10x CCD/CMOS Dust Illuminating LED Sensor Loupe is a good compromise between the the expensive and cheap loupes. I just placed the order for the Opteka I will post my review on this blog. I think for the price you cannot go wrong considering the price and the features of the loupe. I choose the Opteka based on the number of LEDS and the magnification power. as compared to the "lenspen loupe" "dot line loupe same as the GGS CCD cmos senor loupe from china" " Visible Dust BriteVue Sensor Loupe 7X" If anyone has more thoughts on this please post.
01-04-2013, 02:33 AM   #6
Hi
Make sure there is enough room between the loupe and the sensor to enable you to pick up the dust with a brush (or whatever) while you are looking through the loupe. Otherwise you are flying blind to pick up the dust you spotted.
I use this one and it works perfectly, wouldn't be without it.
GGS Sensor Loupe Sensor CCD CMOS Cleaning Kit for DSLR Digital Camera | eBay
Greetings
01-04-2013, 10:35 AM   #7
Thanks for all the input I know that there is a wet and a dry method to clean the sensor. Wet "sensor swab" or dry using the brush method Sensor cleaning system for digital camera. or is the bet to use the Pentax Image Sensor Cleaning Kit O-ICK1. I have been looking around and i found the video below from the Leica factory showing how they clean the camera and it seems that they are using the Pentax Image Sensor Cleaning Kit O-ICK1. and also a wet method any thoughts
Leica M9 - Cleaning the sensor | Flickr - Photo Sharing!
01-07-2013, 05:20 PM   #8
The Loupe just arrived. I used it on my old Nikon SLR. I must say that it does its job and I was able to see the dust clearly and clean the camera. The leds work great but they do not seem to be as powerful as the Visible Dust BriteVue Sensor Loupe 7X from the pictures i have seen on the internet. In all you are able to see all the inside of the camera and it is nicely focusd and the LEDS are placed at an angle so that they all shine at the center of the camera. I am happy with my purchase.
dot, dust, line, loupe, opteka, pentax help, sensor
sensor cleaning woes zosxavius Pentax DSLR Discussion 49 03-07-2012 07:58 PM
Sensor/Mirror Cleaning godavari Pentax K-5 17 12-01-2011 11:55 AM
Sensor cleaning with lens on? nima Troubleshooting and Beginner Help 8 01-21-2010 10:01 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Cleaning K10D Sensor with Eclipse pentaxbling Pentax DSLR Discussion 2 09-05-2007 01:39 AM
All times are GMT -7. The time now is 02:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
