01-05-2013, 07:25 AM   #1
External Flash K30 malfunction
I will try to keep this short. Bought a Bell&Howell Z480AF series flash. This flash is awesome and works perfectly with my K20, However: when trying to use it with my K30 the flash works but continues to flash like a strobe light until I turn it off.. I have tried the Manual mode, TV modes and read the instructions with NO results. According to my flash information it is compatible with the K30 On page 240 of the K30 instructions it states to set the external flash mode to P-TTL not sure what that setting is specifically. The flash documentation does list this flash as a Pentax Digital P-TTL.. Let me guess, external flashes do not work with the K30, ha, ha.
Any suggestions will be appreciated.
Theo
01-05-2013, 11:40 AM   #2
I have a third party flash that works fine with my K200D, but will not work in P-TTL mode with my K-R. I emailed the mfg of the flash asking about this and was told that Pentax has changed the electronic signals that the camera uses to communicate with the flash, starting with the K-X and that the flash will not work with newer models. Some of the lesser flash makers don't show this in their spec sheets. Some flashes can be updated, like the Metz, and Sigma, I believe. You can search the net and see if you can find an update for your flash, but I will be very surprised if you find an update for Bell & Howell.
01-05-2013, 02:00 PM   #3
Thank you GP I appreciate the information. Go figure! I guess I will use my K20 with the flash and will search the net for a update, but like you said I two would be surprised to find one for this flash.
flash, instructions, k30, mode, pentax help
External Flash DomK20D Troubleshooting and Beginner Help 7 10-21-2012 09:42 AM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
Metz 45CL-4 flash malfunction papa john Welcomes and Introductions 2 01-27-2012 01:54 PM
repair internal flash or buy an external flash Capslock118 Pentax DSLR Discussion 11 11-23-2011 05:22 PM
external flash r00t_b33r Photographic Technique 8 03-06-2011 12:08 AM
All times are GMT -7. The time now is 01:19 PM. | See also: NikonForums.com, part of our network of photo forums!
