01-05-2013, 01:40 PM   #1
My K20D doesn't won't focus
Hey everyone,
I need to ask a little advice of the crowd. I have a K20D that I haven't shot much with over the past 6 months. Last night when I put either of my auto-focus lenses on the camera, it wouldn't consistently focus. About every third time I remounted the lens to the camera, auto-focus would work. The rest of the time I would just hear "whirr-whirr, whirr-whirr" and it would look through the viewfinder as if lens was changing its focal distance by about an inch. It certainly sounded like the camera was making an attempt of it, but it couldn't change the focal distance. I've not had this problem before.
I'm attaching a couple pictures I took of the lens mount, specifically focusing on the AF drive pin. Does it look OK to you guys, or does something look out of whack? Any thoughts?
Thank you,
01-05-2013, 01:44 PM   #2
Shoot. The title of this thread is what happens when you start one sentence and finish another....
Should say "My K20D won't focus"
01-05-2013, 01:52 PM   #3
Raffwal's Avatar
What lenses do you have? The ones with SDM focusing motor are notorious for spontaneous breakdowns. Although it would be strange for them both to break at the same time. Anybody near you with a Pentax camera or lenses to see which is broken?
EDIT: OK, your signature shows it's about FA lenses wth screw AF. So forget about my theory.
01-05-2013, 06:49 PM   #4
VisualDarkness's Avatar
I had/have one lens (dunno which) that didn't always line up with the screwdrive, I think it was bacause it got stuck. Take the lens of and turn the screw manually and see if works better after a few workouts.
01-06-2013, 07:31 PM   #5
Maybe this was due to my own error. Seems as long as I avoid depressing the lens release button while mounting the lens to the body, the auto focus still works. Maybe if that button gets depressed while turning the lens, the screw heads don't line up?
On the plus side, I got a nice macro shot of the AF drive pin...
01-06-2013, 08:04 PM   #6
Ash
Ash's Avatar
Very funny, but yes, if the lens AF drive shaft is not perfectly in line with the female socket of the lens, it will fail to latch and drive the lens's focus ring. Make it a habit to just mount the lens without depressing the lens release button. You should always hear a satisfying click once you've mounted the lens properly.
auto-focus, camera, distance, focus, k20d, lens, pentax help, time
K200 won't focus rober Troubleshooting and Beginner Help 2 12-22-2012 10:50 AM
K100D Super + Helios lens = doesn't focus properly euzha Troubleshooting and Beginner Help 2 12-11-2012 04:26 PM
K20D won't/can't store some photos Kristie B. Troubleshooting and Beginner Help 17 06-04-2012 09:47 PM
Manual Focus why doesn't AF button work rsoph Pentax K-5 & K-5 II 6 12-18-2011 05:27 AM
K20D doesn't shoot sometimes BaresPhotography Troubleshooting and Beginner Help 8 01-17-2011 03:34 PM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
