01-07-2013, 04:39 PM   #1
K-x and using AF400T flash
I want to continue using my beloved Pentax AF400T flash (because of its practical huge grip, because of the 220V alimentation possibility while shooting).
But, using it with a modern K-x is much more tricky than with the 1980-PentaxLX !!
cam set at M, 1/100sec, f set at the lens (e.g. f:8);
cam AF function OFF
viewfinder shows me that the flashgun, linked to cam via dedicated 5-pin Pentax chord (the same I ever used before), is ready to flash
the flash spurts only very seldom:
I got the impression that I've got to count mentally "1-2-3-4" slowly, AFTER the little hexagonal focus signal in the viewfinder has lit up, or else the flash won't shoot. Impossible to make spontaneous model shooting with it (I like the 400T to trigger my multiblitz strobes).
I've tried everything possible in the MENU sub-section (e.g.:AE -AF being linked or not).
I've measured the pins of the chord with an Ohmmeter: they are OK.
What now?
01-07-2013, 10:02 PM   #2
p38arover's Avatar
This might help:
https://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/166859-...ocus-400t.html
01-08-2013, 06:48 PM   #3
oldMElove, when the ready lamp is on and when you push the "test" button, does the flash fire every time?
If the flash doesn't fire every time, I'm afraid that its life is over....
af400t, cam, camera, chord, flash, k-x, pentax, pentax help, photography, viewfinder
Setting K-x using Bulb and max 9 exposures help Twiggy36 Pentax DSLR Discussion 8 07-29-2012 10:23 AM
K-X: Using the Pop-Up Flash dmfw Pentax DSLR Discussion 6 12-05-2011 04:03 AM
Need help using Vivitar flash as wireless slave w/K-x kodai84 Troubleshooting and Beginner Help 6 09-29-2011 09:18 PM
Flash Settings Using M Series Lenses On The K X shutterpuppy Pentax DSLR Discussion 9 01-07-2011 12:01 PM
K-x: Using flash as AF assist lamp (only) Bulldogface Pentax DSLR Discussion 7 02-18-2010 06:14 AM
All times are GMT -7. The time now is 07:09 PM. | See also: NikonForums.com, part of our network of photo forums!
