01-15-2013, 01:57 AM   #1
trishytee's Avatar
slow writing
I think this has been done to death but I am desperate! Two days ago I was doing some slow shutter with nd filter and pictures were opening up almost instantly. today I am back to the slow writing. For as long as I have the shutter open that's how long it takes for the pic to download.( I was doing 30second firework shots a few weeks ago and no probs). I have the noise reduction turned to off, no lens corrections on, have reformatted my 'sandisc extreme pro' but nothing is helping. Can anyone help with this.
01-15-2013, 02:03 AM   #2
trishytee's Avatar
PS
I have tried several different cards all with the same result.
01-15-2013, 02:16 AM   #3
trishytee's Avatar
Fixed
I have found the culprit, which is really bizzare as I have never touched this setting. I had turned off 'noise reduction' and then someone mentioned "slow shutter speed noise reduction" sssnr I found this in the C section and turned it off. Now no slow writing. But I am still really puzzled about why it has never been a problem until today? It has never been turned off before? So any deep thoughts on this mystery would be appreciated. (It is a K7)
01-15-2013, 02:50 AM   #4
It should be on by default, but it takes a few things into consideration besides shutter speed to determine whether or not to do a dark frame, like ISO and temperature. Maybe it was cooler when you tried it before.
Also, I believe the K-7 will still do a dark frame if the exposure time is longer than 30 seconds. That is what the manual says at least, that could have changed in a firmware update.
01-15-2013, 02:56 AM   #5
QuoteOriginally posted by trishytee Quote
If you have SSSNR turned on, then the camera will process the photo for the same amount of time as the exposure. That's how it is on all Pentaxes AFAIK (and yes, I do believe that they could optimize this particular feature to not take as long).
01-15-2013, 07:07 AM   #6
Anvh's Avatar
How?
Like you say it needs to take a darkframe exposure with the same settings so if you use 30seconds the DFS also needs to be 30s how do you want to speed it up?
01-15-2013, 07:16 AM   #7
QuoteOriginally posted by Anvh Quote
How?
In theory it could just store the dark frames for certain parameters, like at 100 ISO, 30s exposure and a certain temperature range the noise is likely to be the same, so instead of taking a new dark frame it uses the stored one. Of course, every sensor isn't exactly the same, so they couldn't just preload dark frames onto each body with the firmware.
Maybe have it set to store a dark frame in the buffer so the first shot requires you to wait for the dark frame, but each shot after that with the same parameters would just use the same dark frame, saving time.
I just leave it off and fix the hot pixels in post, I can't really tell the difference in the results.
01-15-2013, 09:09 AM   #8
Anvh's Avatar
But pixels also change over time.
For astro photography you do DFS manually before each shoot
pentax help, shutter, writing
Slow writing to card ? annieogg Pentax K-5 18 04-18-2012 04:07 AM
Slow photography. Really slow... baro-nite Photographic Technique 5 01-03-2012 04:17 PM
slow writing? fg-one Pentax K-5 3 10-15-2011 01:47 PM
effects filters slow down camera,turn off filter and camera is still slow zorak Pentax K-r 7 10-05-2011 06:12 AM
Slow AF? Slow TTL? Check 'em batteries!!! jboyde Pentax DSLR Discussion 11 04-30-2009 06:41 PM
All times are GMT -7. The time now is 11:36 PM. | See also: NikonForums.com, part of our network of photo forums!
