01-17-2013, 04:56 AM   #1
smc pentax m 50mm 1.7 lens won't stop down
Hi Folks,
attaching my question here hoping for being rescued from my despair: My smc pentax m 50mm 1.7 lens on my K-01 just won't stop down. It doesn't feature an A-Setting.
- function of aperture ring / diaphragm on lens is ok if lens is detached or camera powered off
- menu setting of aperture ring is ok and camera releases (however only at f1.7
- AF switch on the body next to the lens ist set to MF
- lens aperture ring is set to, let's say f8
--> powering the camera on, opens the lens to f1.7 and it never stops down and it doesn't do so upon release, too.
What am I doing wrong?
01-17-2013, 05:47 AM   #2
Well solved it. It won't work in ISO-Auto Mode.
Is there absolutely no way to get a permanent metering and use ISO-Auto? Would be veeery handy ....
Having to press the green button prior to each shot is somewhat silly.
01-17-2013, 07:02 AM   #3
GabrielFFontes's Avatar
A very simple trick that might help you a bit (for example, i used to use my M 50mm 1.7 at f2 or f2.8 a lot of the times, so this helped a lot).
Pentax M lens "trick" - YouTube
01-17-2013, 07:47 AM   #4
Not a Number's Avatar
You could try tricking the camera into thinking an "A" lens is attached: short out the "A" pin and insulate the proper pins for min and max apertures.
01-17-2013, 08:16 AM   #5
Thank you very much. The M lens trick ist just great and quickly implemented.
I'll check out the pin insulation
09-11-2013, 03:50 AM   #6
I like the M lens trick, too. What I would like better is a firmware upgrade that disables the offending contacts.
Pentax advertises that older lenses can be used with the K-01 and we shouldn't have to use "tricks" to get the camera to perform as advertised.
50mm, 50mm 1.7 lens, aperture, camera, f1.7, lens, pentax, pentax help, pentax m 50mm, smc pentax
SMC Pentax-M 50mm 1.4 Won't Stop Down brofkand Pentax SLR Lens Discussion 10 08-03-2014 12:32 AM
Non-Pentax K bellows unit - lens won't stop down timh Troubleshooting and Beginner Help 7 04-29-2012 01:42 PM
K-7 won't stop down with auto extnsion tube fitted. katanaismybike Pentax DSLR Discussion 9 06-07-2010 03:14 PM
K20D Won't Work with my 50mm SMC 1.7! HELP! PentaxForums-User Pentax SLR Lens Discussion 2 03-08-2009 12:06 AM
SMC M 50mm 1.7 Stopping Down gingerburn Pentax SLR Lens Discussion 3 07-04-2008 10:49 AM
All times are GMT -7. The time now is 09:29 PM. | See also: NikonForums.com, part of our network of photo forums!
