01-28-2013, 06:56 PM   #16
QuoteOriginally posted by excanonfd Quote
There should be a tiny screw holding the spring, undo the screw and leave both off the adapter.
Is this the leaf you're talking about?
01-28-2013, 11:29 PM   #17
That's the one, when you look it it from the side there should be a small screw (usually Phillips but I've seen slotted ones as well) holding the spring in place.
01-29-2013, 07:21 AM   #18
Thanks Excanon. I made it. Easily my most favorite lens now. I'll practice with it more
PENTAX K-5  Photo
PENTAX K-5  Photo
PENTAX K-5  Photo
PENTAX K-5  Photo
PENTAX K-5  Photo
04-09-2014, 06:43 PM   #19
pentacon six mount
hi everyone, new user here, have a k1000 and decided to buy an adapter to use my pentacon six bayonet mount lenses on this and purchase a k30 as i saw the lenses are backwards compatible on the mount, so i found this adapter on ebay, Tilt Adapter for Use P Six Kiev Lenses on Canon Nikon | eBay , anyone know if this actually would work? thank you.
04-11-2014, 12:31 AM   #20
@ tiberiu6x6
I've no experience with this adapter, but I've heard about it and it should work.
However, because of the crop factor of a MF lens used with a 24x26 film format, any shift function won't make much sense. To get a proper effect on FF (24x36) you would need a MF lens which was extreme(!) wide angle on its own format.
If you are looking for tilt, this may make sense in some cases.
There are cheaper P6-> PK as well as P6 -> M42 adapters (without tilt/shift). I am not sure how stable a combination of a (heavy!) P6 lens with stacked adapters ->M42->PK would be, but it would work mechanically and optically.
I was myself looking for some time for such adapters to use the superb P6 CZJ Flektogon MC 2.8/80mm on my Pentax SLRs and DSLRs, but even on German eBay used ones (M42) turn up only once in every 3-4 months, and auctions will end at $50-$70. The PK version is even rarer (and more expensive). I have more or less given up.
camera, k-5, pentacon, pentacon 135mm f2.8, pentax help, photography
For Sale - Sold: 3rd Party M42... Soligor 200mm F3.5, 2x and 1.85x TC's MightyMike Sold Items 149 01-30-2014 07:42 AM
Pentacon 135mm F2.8 ~ 15 blades = BOKEH MONSTER ~ 6 blades = NOT ? minahasa Pentax SLR Lens Discussion 3 09-01-2011 06:26 PM
For Sale - Sold: Pentax FA 28mm f2.8, Pentax K 135mm f2.5, Tamron Adaptall SP 70-210 f3.5 (19AH EricR Sold Items 9 03-05-2011 04:58 PM
For Sale - Sold: Pentacon 135mm f2.8 M42 Thread Mount (Worldwide) rrodgers Sold Items 6 12-31-2010 07:07 AM
Does anyone have a Pentacon 135mm f2.8? little laker Pentax SLR Lens Discussion 6 11-05-2009 01:37 PM
All times are GMT -7. The time now is 12:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
