01-29-2013, 05:40 AM   #16
Thanks Jim, for the card slot cleaning suggestion.
OK I received two new 8 GB SD cards in the post via ebay and they both worked perfectly in the camera.
I inspected the two "damaged" 4 GB SD cards that were not recognizable by the camera. The metal connectors of both are badly scratched compared with the new ones. But both still work in my notebook computer.
Thanks for the help. I will have to be more gentle with inserting the cards into the various devices.
01-29-2013, 09:50 AM   #17
Docrwm's Avatar
QuoteOriginally posted by wedwardes Quote
Thanks for the help. I will have to be more gently with inserting the cards into the various devices.
You can try to clean those connectors with a light cleaning using a metal polish. It can go bad on you if you use too much or use a non-cream type but it can also bring them back. SD cards that are used regularly do have a life span though and at some point they just need to be scrapped.
card, cards, k-x, message, pentax, pentax help, pentax k-x
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
K20 "Memory Card Full" Error message FHPhotographer Pentax DSLR Discussion 2 02-10-2012 10:22 AM
K-x "aperture priority" records as "automatic" in meta data charlestm Pentax DSLR Discussion 3 12-05-2011 12:12 PM
A homemade "Pentax" camera... no really!!! ve2vfd Photographic Technique 3 03-11-2011 01:03 AM
Avoiding "No card in the camera"? Kitty Pentax K-r 2 01-17-2011 08:41 AM
All times are GMT -7. The time now is 08:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
