02-01-2013, 12:12 PM   #1
SD card write-protect unremovable?
Weird thing happening with all my SD cards (so I presume it's the laptop I'm using...) - can't copy into them, paste into them, but I can copy from them (cut not also possible).
I try to reformat it in the camera - it does. I try it on my PC - doesn't work. I tried googling and found lots of other people having the same problem, no concrete solution though. Now I can't copy new firmware data into the card..
Anyone encountered this behavior yet? I'm using Windows 7.
02-01-2013, 12:20 PM   #2
Sagitta's Avatar
Going on a wild guess, are you trying to muck with the files as a user other than the administrator? It sounds like you have a permission turned off of some sort in regards to the ability to modify the drive letter that the card is assigned to.
02-01-2013, 12:31 PM   #3
QuoteOriginally posted by Sagitta Quote
I'm the only user of this PC so there are no other user profiles to use. I can't remember when it happened (perhaps after one of the automatic updates) that the logo of the SD card drive changed to one that looks like a card with "SD" on it- thought it was an upgrade of sorts.
Then, I could copy photos from the card to the PC... then I realized I couldn't write into them. What seems to be the problem? also thanks for the quick reply ...
02-01-2013, 12:34 PM   #4
mrNewt's Avatar
Have you tried it on another computer? Still acts the same?
Try and do a system restore to the date before the update you are talking about; and see if it still does the same.
And just for the hell of it ... check your administrator permissions.
02-01-2013, 12:41 PM   #5
QuoteOriginally posted by mrNewt Quote
Will try it on my brother's PC when I get the chance. But as far as admin permissions are concerned, USB devices like flash drives and external drives work fine; just the SD cards won't.
02-01-2013, 12:43 PM   #6
mrNewt's Avatar
QuoteOriginally posted by Alizarine Quote
Btw ... try this:
How to remove write protection from SD card? - Yahoo! Answers
(read the whole thing!!)
02-01-2013, 03:02 PM   #7
Na Horuk's Avatar
SD cards have a little lever on them, is it in the correct position?
02-01-2013, 09:33 PM   #8
How to remove write protection from SD card? - Yahoo! Answers (read the whole thing!!)
No luck maybe SysRestore is the key..
Yes, I've even tried switching the lever "in-between" in all cards - didn't work also.Could it also be the work of a virus?
04-04-2013, 08:14 PM   #9
Yep I got the same problem. Only noticed when I tried to update my firmware today. Formatting works on the camera but attached to the comp its "read only" under disk management.
The tab on the side is set to unlocked. So please don't offer that solutions.
04-04-2013, 09:05 PM   #10
Sagitta's Avatar
I did some research thinking it was my SD card causing me my EXIF woes (it wasn't) - apparently all SD cards have a notch on the *other* side of the lever. This notch makes the card writable in portable devices, and non-writable on PCs. Its supposed to help combat piracy of music and video as people can't copy that stuff to an SD card and transport it.
The trick is to tape over that notch without having whatever you used to tape it with come loose and gum up your PCs SD slot.
04-05-2013, 06:27 PM   #11
this is a virus, i have the same problem, in some cases i take off the SD of the computer and put in again and work, or if formar the SD in the camera
04-05-2013, 06:51 PM   #12
DeepThrob's Avatar
I'd try one of those $12 walmarts /targus usb multi-card readers
04-08-2013, 10:23 PM   #13
For some odd reason my cards are working again normally. I don't know when, but I can now cut/paste into and from the card. The "SD" icon is still there when I insert the card, but there's no more "card is write-protected" error
All I remember was un-installing some toolbars in Firefox and cleaning up registry
04-09-2013, 01:37 AM   #14
Moderator PEG Judges
Kerrowdown's Avatar
Glad you got it sorted and got back to full speed ahead on the photography front.
copy, pentax help, sd
PNY Class 10 card inconsistent write speed bwDraco Troubleshooting and Beginner Help 16 07-25-2011 02:21 PM
Crap! My new class 10 sd card run much slower than my old class 4 sd card... liukaitc Pentax Camera and Field Accessories 15 05-31-2011 01:39 PM
Write Protect Tab Broken Off Eye-Fi Pro2 Card Tonto Troubleshooting and Beginner Help 6 04-03-2011 10:18 PM
Scratched SD Card Contacts? Oh, and Don't get pqi SD Cards. AgentFixer Pentax Camera and Field Accessories 4 02-21-2008 09:16 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, part of our network of photo forums!
