Originally posted by arcturus I'm still trying to grasp the concept here. Is exposure bracketing the same as EV bracketing?
EV simply means Exposure Value, how much light is falling on a subject.
Camera meters assume their measure of
reflected light is the Exposure Value.
The amount of light reflected from an object is often different from how much light falls on an object, aka incident light.
If you use the camera's recommended exposure value (AE), black cats become gray, snow becomes gray, etc. EV compensation on a camera allows you to adjust the exposure for the reflective properties of the subject. It's why exposing +1 to 1.5 stops high for snow or a bright beach is recommended. Same with exposing -2/3 to 1 for a green forest or a black animal.
Bracketing makes multiples exposures, each with a slightly higher or lower exposure setting from the camera recommendation. Also useful for HDR.
If you bracket an exposure, you typically make at least 1 exposure a half stop or stop high, a nominal exposure and at least 1 exposure a half stop or stop low. If you're shooting slide film, its a practical approach. Negatives are more forgiving, as are digital raw files.
I skip the camera meter and use manual exposure based on an incident light meter reading or my best guesstimate of one. If I were making an HDR photo, trying to capture the maximum dynamic range of a scene with a lot of dynamic range, I'd bracket my manual exposure and combine the exposures in software.
