02-02-2013, 09:43 PM   #1
Flash probelm
I use K-5 with 2 flash(YN560EX and TT520) I set 2 flash left and right. camera use own flash. I put Wireless mode. When I take pic, only camera's flash work. Other flashes are working but it takes different time each. What is my problem??
02-02-2013, 09:51 PM   #2
The camera's wireless mode is for commanding wireless P-TTL compatible flashes, it won't work with the "dumb" slave mode in those flashes. You need to set the flashes to the slave mode that ignores the preflash, usually called S2 on the Yongnuo. The camera should be in normal flash mode.
The best solution, however, is to get some radio triggers. They are more reliable and predictable than optical triggering.
camera, flash, pentax help, photography
Kr wireless wont flash without built in flash selected Phil_jman Pentax K-r 14 01-11-2014 03:47 PM
Trigger remote flash without popping up built in flash godavari Flashes, Lighting, and Studio 23 10-15-2012 01:32 PM
Kx and Bower SFD926P flash=no flash? hray Troubleshooting and Beginner Help 2 12-25-2011 06:22 PM
repair internal flash or buy an external flash Capslock118 Pentax DSLR Discussion 11 11-23-2011 05:22 PM
All times are GMT -7. The time now is 04:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
