02-03-2013, 12:21 PM   #1
slip's Avatar
pentax remote F
does the pentax remote battery work with the k5iis? I can't get it to work, battery seems fine
thanks
randy
02-03-2013, 12:46 PM   #2
jatrax's Avatar
Mine works. You do have to set the drive mode to remote. And check the AF with remote setting to make sure it is what you want: C3.18.
02-03-2013, 12:49 PM   #3
Moderator PEG Judges
Kerrowdown's Avatar
Remember also it's a fairly limited range and direct line of sight operation.
02-03-2013, 01:06 PM   #4
slip's Avatar
Hi and thanks
I have put it in remote and I get no response from the camera no matter what the distance is
Not sure what C3.18.
Thanks
Randy
02-03-2013, 02:01 PM   #5
jatrax's Avatar
QuoteOriginally posted by slip Quote
Press the Menu button; go to the Custom section; Tab 3; Item #18. It determines whether the camera auto-focuses when the remote is activated. I doubt it has anything to do with your problem, just wanted to point out that it is there and changes the behavior of the remote.
How long have you had the Remote F? It is possible the battery is dead. Do you have another camera to try it on?
02-03-2013, 03:27 PM   #6
slip's Avatar
I bought it from a forum member a few months back...brand new in box. did not work on my k10 either. tested and put in another battery with same results. tried putting the battery in the other way and it didn't help.will look into your advise to see if it will help.
thanks
randy
02-03-2013, 07:51 PM   #7
A quick test: Aim the remote at a cheap camera such as your cell phone and see if it lights up. The pic is quick hack work but you can see the wireless remote working in the square.Mine is the O-RC1
battery, pentax, pentax help
Pentax Remote F battery PentaxNewbie Accessory and Memory Articles 22 01-16-2014 06:55 AM
PENTAX Waterproof Remote Control O-RC1 vs. Remote Control F jpzk Pentax Camera and Field Accessories 8 12-02-2013 08:11 AM
For Sale - Sold: Canon Remote Switch (compatible with Pentax cameras) & Pentax Remote F indytax Sold Items 6 09-04-2012 10:47 AM
Misplaced Pentax Remote Control F kitkat Pentax Camera and Field Accessories 16 07-02-2012 07:16 AM
For Sale - Sold: Pentax Remote F IR remote (CONUS) Ed n Georgia Sold Items 2 03-28-2011 03:01 PM
All times are GMT -7. The time now is 06:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
