02-08-2013, 07:41 AM   #1
k-5 firmware 1.14 become soft
after what i did last firmware update at my K-5, pictures become more soft are not the same sharp like before
anyone have the same problem?
can i pun back the old firmware? was 1.01 original firmware
02-08-2013, 07:56 AM   #2
ChrisTrevino's Avatar
I'm not having any focus/sharpness problems with the newest firmware.
Check your AF Adjustment for whatever lens to make sure it didn't get reset.
Check the lens to make sure there's not something on either the front or rear element causing it to be soft.
Try a shot on a tripod with Shake Reduction off so you know the camera won't move.
02-08-2013, 08:24 AM   #3
I am not having any problems with the updated firmware, did you have any adjustments for lenses that may have been corrected in the new update?
02-08-2013, 09:42 AM   #4
focus is exactly where it should be, is not sharp, but not how was the before the firmware update, I tried this with 2 objectives very sharp, like tamron 28-75 2.8 and smc-a 50mm f1.7
I can put back old firmware??? i was very satisfied by old firmware
every settings on camera are the same before firmware, I look on my old pictures and I compared with some picture made after update and differences are very sensible
02-08-2013, 10:02 AM   #5
I understand you can't roll back firmware to earlier versions, but I think the point being made is whether previous fine AF adjustments or other settings - sharpening for example - were 'lost' during the upgrade and simply need re-doing?
02-08-2013, 10:23 AM   #6
todd's Avatar
I've also read elsewhere that it is advisable to reset the settings after the firmware update. I haven't done so and have been fine, but I've just been using one MF lens since the update and if I were to notice anything weird that is the first thing I would try.... Have you tried to reset your settings to default yet and then redo your preferences?
02-08-2013, 10:31 AM   #7
Do you shoot JPEG or RAW?
If you shoot JPEG make sure you check the Custom Image settings again to make sure the sharpness is not turned down.
I own both the lenses you say you tried and both of mine work fine on the camera. I had to set my Tamron 28-75 to -7 on the Focus Adjustment though because the lens itself had a focus issue. With my 50mm f/1.7 or my 1.4 Manual Focus a lot of times wide open at 1.7/1.4 they are soft. Especially since manually focusing with such a shallow depth of field is hard. Check the Diopter on the Viewfinder to make sure it's in the right position for your eye sight.
This firmware doesn't affect focus in such a way that it would be giving you soft images. You should 1st go through all the proper steps to redo your camera settings and then try to figure out what to do.
02-08-2013, 02:12 PM   #8
Schmidlapper's Avatar
Some people myself included have had to readjust their lens fine adjust settings on the K5, after the 1.14 update as they seem to be different afterwards. There is more examples in the DSLR, K5 forum.This is different from just reseting the camera and then putting your old lens adjustment numbers back in. All three of my DA limiteds required completely different adjustment settings. If that is the case for your situation as well, then it might explain the sharpness softening, as your old settings may now no longer be accurate.
02-09-2013, 02:52 AM   #9
I shot only in raw file.
every setting, about sharpness in camera do not affect raw files???
02-09-2013, 05:38 AM   #10
Focus adjustment related camera settings such as Lens AF fine adjust, do indeed affect RAW files too.
02-09-2013, 08:07 AM   #11
Fogel70's Avatar
QuoteOriginally posted by giani Quote
It deends on what software you use. If using the software supplied with the camera, then jpg setting will be used by raw conversion software, but not on all other RAW conversion software.
If you shoot jpg, are they soft too? If not, then the problem is probably not in the camera, but in the settings used by the RAW conversion software. It might be that the software do not recognize the camera with new firmware?
02-10-2013, 02:25 AM   #12
I have a BIG thank you for all people who helped me for this problem. After what I reset to default everything in camera and I remade all setting again, camera work fine now.
Is good to know for future firmware or for every update.
02-10-2013, 05:59 AM   #13
Glad to hear it Giani
firmware, k-5, k-5 firmware, pentax help
Firmware Update K-5 V1.14 Docrwm Pentax K-5 109 03-29-2013 05:53 PM
K-5 II and K-5 IIs Firmware 1.01 Available Adam Pentax K-5 10 01-18-2013 08:35 AM
All times are GMT -7. The time now is 03:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
