02-09-2013, 01:31 AM   #1
K-5II: troubles with a lens and the software installation
Few days ago I bought my new K-5 II.
Soon I discovered that the DA 16-50 mm lens didn't work with it, while it works perfectly with my K10D. The other lenses I use work properly with the new camera. Any idea of what the problem could be and if there is any solution? (I've just done also the software upgrading).
I also had problems with the installation of the Camera Utility on my Mac: I can't install it even clicking on the icons on the CD-ROM. Any help?
Thanks a lot
02-09-2013, 01:45 AM   #2
QuoteOriginally posted by Orlando Quote
Thanks a lot
What do you mean it doesn't work? Does the camera refuse to take pictures, is the AF dead, etc?
If it's the AF and your K10D was using the screwdrive mechanism, it could be that the lens's SDM is broken.
02-09-2013, 06:10 AM   #3
Re 16-50, what Adam said
Re Camera Utility disk, I was unable to get it installed on my Mac Pro as well. I use LR4 instead.
02-09-2013, 06:54 AM   #4
treebeard's Avatar
Thanks a lot
Yes, it might help if you clarified, "the DA 16-50 lens did not work with it".
02-09-2013, 06:58 AM   #5
Rnovo's Avatar
Give us a better description of the problem(s). I have a K5IIs and the same lens, works just fine...
No help for the software as I use LR4 and CS5.
02-09-2013, 07:30 AM   #6
chuck_c's Avatar
Thanks a lot
I am not sure why you are having difficulties with the Pentax Camera Utility. I have it ( version 4.30 ) installed on a 27" iMac Intel Core i5 ( late 2009 model, with version 10.8.2 OS software), and it does function, although sluggishly. You might want to check and see if your Mac software meets the minimum requirements for that version. I do, however, prefer to use LR 4 and PS CS6.
02-09-2013, 08:13 AM   #7
manacho2005's Avatar
What Adam said:
If your K10's firmware is older than 1.30, than unfortunately your 16-50's SDM has bit the dust :-(
02-09-2013, 10:38 AM   #8
If your K10D was using the screwdrive mechanism it ought to be rather loud. The SDM is close to soundless.
03-12-2013, 08:20 AM   #9
QuoteOriginally posted by treebeard Quote
First, thanks everyone for the answers and sorry for not entering here since then (very busy time).
What I mean is that when I press half way the AF button the lens doesn't focus...
03-12-2013, 09:05 AM   #10
aleonx3's Avatar
Most likely as Adam said, the SDM motor is dead or sluggish (when battery low). Your K10D likely uses the screw drive motor since it is available and working with the DA*16-50.
03-12-2013, 09:09 AM   #11
What a bad news!
Thanks anyway
camera, installation, lens, pentax help, software
K-5II P-TTL overexposure with tilted flash - test and analysis Noam Pentax K-5 116 02-08-2014 01:11 PM
K-5II or K-5IIs - which one will you choose if the price is the same? frank Pentax K-5 54 06-20-2013 03:45 PM
Pentax K-5, K-5II and K-5IIs rear sync broken with manual lenses Nass Pentax K-5 17 02-25-2013 05:24 AM
From a K-7...K-30 or K-5II? Daemos Pentax DSLR Discussion 14 11-09-2012 07:04 PM
Debating a K-30 purchase over the K-5II/s... Sagitta Pentax DSLR Discussion 16 10-13-2012 10:34 PM
All times are GMT -7. The time now is 02:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
