02-09-2013, 05:33 PM   #1
Monochrome Photos in Color When Viewed on PC
While using my K-5 I took some photos with the camera set to RAW and the Custom Image set to Monochrome. When I viewed them on the camera they appeared black and white, but when viewed in Picasa Photo viewer or Adobe Camera Raw or Bridge, they have color. I checked to see if I had set the Memory to not record the Custom Image setting, but it was set to record it. I'm at a loss as to why this would happen. It's not a pressing problem, but it's still annoying. Any one have any ideas?
02-09-2013, 06:07 PM   #2
K(s)evin's Avatar
Custom Image only applies to jpeg, not RAW files.
02-09-2013, 06:13 PM   #3
Na Horuk's Avatar
And when viewing raw on camera it only shows you a jpeg preview of the raw, so on camera it will look bw (or whatever other digital filters you have set). Any good raw editor will allow you to turn the image bw (and customize it)
02-09-2013, 06:21 PM   #4
Miguel's Avatar
QuoteOriginally posted by StupidPlant Quote
As noted RAW is RAW and the B&W you see is a jpeg from your camera settings. I believe that by using the included Pentax Utility you would be able to output a DNG or jpg with the B&W setting you chose.
M
camera, color, custom, image, pentax help, photos, record
Photos on Memory Card, But PC Reads 0 Files Kbace Visitors' Center 3 10-09-2012 05:32 AM
Zooming in on a photo on your pc geoles2 Troubleshooting and Beginner Help 3 05-25-2011 01:39 PM
Photos view fine on camera, but when uploaded have color casts. T9000 Pentax DSLR Discussion 7 06-27-2010 10:15 PM
Should images be viewed at 100% when sharpening? alehel Pentax DSLR Discussion 14 04-11-2009 09:32 AM
Lost photos on pc . Any tips? ronald_durst Photographic Technique 6 04-11-2008 12:44 AM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
