Originally posted by zoolander The spider was light blue, the image is not over exposed, images underexposed didn't reveal the full/true color blue. The blue simply disappeared. Sony A65 does not overexpose, its a very competent camera.
All cameras can be made to over expose. And if you really knew what you were doing you would have used the camera in manual mode, and not have used flash. The reason that image of the spider was over exposed is because you didn't use flash exposure compensation, the second reason why that image is unlikely to have been contaminated by IR is this:
Spectrum for Nikon SB-16 Xenon flash tube - this is pretty representative of all Xenon arc tubes used in modern flash units. Many flash tubes are made of type of glass that filters the flash output to attenuate UV and IR light, but there is still a
considerable spike in UV output. Studio flash tubes typically have stronger UV filters on their flash tubes
Xenon flash tubes do produce some IR, but not enough of it to cause problems with colour rendering - camera manufacturers go through a considerable amount of trouble to test the equipment they make and be sure that their products work well together to produce good results.
