02-13-2013, 01:23 AM   #1
Mirror replacement
Hi,
does anybody know how to remove the mirror of a K1000? There seem to be two little "L shaped" pieces in the front and another one in the back. I am supposed to move those? If so, how? with a screwdriver?
Thanks,
s
02-13-2013, 01:57 AM   #2
altopiet's Avatar
Perhaps you'll find some answers at http://www.pentax-manuals.com/markroberts/k1000_man.pdf
02-13-2013, 12:29 PM   #3
Thanks altopiet! I scanned through the pdf a couple of times and I could not find how to remove just the mirror
Maybe it is so easy that they do not bother explaining that
02-13-2013, 10:15 PM   #4
altopiet's Avatar
S, I found this group Flickr: Discussing Pentax K1000 in Classic Camera Repair & Maintenance. They seem to know a lot about stripping the K1000. The last entry was 2 months ago, but it seems the thread is still active. Perhaps they might be able to help you....I think I've got an old MX somewhere. Unfortunately, it will take some time to look for it. It should be more or less the same as the K1000. If you don't get an answer somewhere, I'll start cleaning the garage, looking for it
02-13-2013, 10:25 PM   #5
Just1MoreDave's Avatar
I don't know for sure, but I think the answer is "Remove all 12 million parts around the mirror box, being careful to note their exact positions for reassembly. Then remove the two screws that hold a part you can't see or access until those 12 million parts are out of the way. Slide out the mirror."
It sounds pessimistic but I have the mirror box right here from an SF1. Maybe a thousand parts is a better estimate. Here's a photo. Look on the right side, slightly above center. See two JIS screws holding on a chrome plate, and a pin sticking out behind them? That's one side of the hinge pin for the mirror. Maybe removing that would allow the opposite end to be removed.
I would consider buying another K1000 before trying this.
02-14-2013, 12:29 AM   #6
Thanks for the info guys!
I think it is simpler than than removing all those parts; but I might be wrong....that's why I was asking in first place :P
thanks again.
02-16-2013, 03:57 PM   #7
I asked them but no news so far
02-16-2013, 05:15 PM   #8
kcobain1992's Avatar
I found this thread on Flickr a while ago. I also tried it myself, but it didn't seem to work. Maybe you'll have better luck.
02-16-2013, 07:17 PM   #9
Thanks Kcobain, I saw the same post a couple of days ago so that's why I was assuming it did not imply dissembling the whole camera. I did try but it feel like the mirror is gonna break if I force it too much...
mirror, pentax help
What do you think the replacement for the K-01 will be like? Glen_S Pentax Mirrorless Cameras 74 01-16-2013 09:47 AM
ZX-5n replacement jamesmck Pentax Film SLR Discussion 8 06-29-2012 03:31 PM
Replacement Batteries (3rd Party), an experience? deanm3 Pentax Q 4 02-22-2012 03:36 PM
pentax mz10 mirror flap spring replacement. njht2 Troubleshooting and Beginner Help 1 04-03-2011 09:33 AM
Hotshoe replacement after fall Mister Guy Pentax Camera and Field Accessories 2 05-29-2010 09:30 PM
All times are GMT -7. The time now is 06:40 PM. | See also: NikonForums.com, part of our network of photo forums!
