Hi!
I did some searching about the live view sensor shake phenomenon in some of the Pentax models. Most of the threads seemed to end to conclusion that the camera body is faulty and needs repair. I have a couple of yrs old K-7 that had never done that.
However, I recently bought a Cosina manual lens (24mm 2.8), that didn't stop down using the green button, because of the anodized aluminium bayonet that insulates all electrical contact pins. So I sanded some of the anodizing off the bayonet. Now everything works very well, but in live view the sensor shakes wildly. If I clean the contacts carefully and put the lens on a couple of times, live view might work normally for a short time, then the sensor starts shaking again.
No other lens does this (DA 35mm, 55mm SDM, Tokina 60-120 f/2.8, Tamron 24mm adaptall f/2.5, kit lens, Tamron zoom.. ).
Any ideas, what could cause this..?
