04-26-2013, 12:40 AM   #16
TastyCelery's Avatar
So for K-30 I need the C or the N version?
04-26-2013, 08:10 AM   #17
...the N, Nikon version ...it has the same pin contact pattern as Pentax...you may need to cover the upper right hot-shoe contact with tape (on the K-30), as this contact triggers the wake up signal, or maybe not...
04-26-2013, 11:35 AM   #18
N version works without any modification
05-06-2013, 02:46 AM   #19
OK ... the N version is being delivered ... will report in about a week how it turns out
05-23-2013, 09:40 AM   #20
I finally received them. As it turns out they have replaced the 602 transmitters with 600, but as I understand they're basically the same.
But there is a (big?) problem! I have a K-30, the 602's, Metz 58-af2 on the receiver and two YN-560 III (they have receivers built-in).
So when I half-press the shutter release and then don't take the picture, all flashes fire when the viewfinder display turns off (if I'm right, that is when camera stops metering).
Please tell me someone here knows how to fix this
P.S. Flashes seem to fire perfectly every time I actually do take the picture, but there is an awful lot of flashing when I'm just preparing to take the shot
05-24-2013, 12:56 AM   #21
I found Yongnuo RF-602 flash triggers and Pentax - Overclockers Australia Forums, and according to this post I have to disable the SP pin on the transmitter.
Can anyone confirm this?
fire, pentax help
RF-600TX replaces RF-602TX in Yongnuo RF-602 Kits adr1an Pentax Camera and Field Accessories 4 02-18-2015 10:14 AM
Yongnuo RF-603's DaveHolmes Flashes, Lighting, and Studio 24 03-08-2014 07:43 AM
Wireless Flash Triggers RF-603 Sandhurst Flashes, Lighting, and Studio 13 03-25-2013 06:11 AM
Youngnuo RF-603 wireless triggers not working jeztastic Flashes, Lighting, and Studio 8 05-07-2012 12:29 PM
Anyone tried Yongnuo YN-04II Flash triggers? jeztastic Flashes, Lighting, and Studio 19 02-04-2012 07:55 PM
All times are GMT -7. The time now is 05:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
