02-18-2013, 10:30 AM   #1
Focal length of this pic
SLRCLUB, ??? ???? ?? ????
When I searching pictures, I found this korean model pictures. I want to know the lens that it used in this pics.
Can someone guess this lens for me? I can not get these pic's meta data.
02-18-2013, 10:37 AM   #2
I'd guess either the Nikon 50mm or 85mm.
02-18-2013, 11:31 AM   #3
Na Horuk's Avatar
Keep in mind that the model is really well lit, is probably wearing contact lenses to make the eyes more dramatic, etc. And probably has been processed. The lens is important, but its won't guarantee you shots like that, unless you make the same setup. And if you have the same setup a Pentax portrait lens (like the 55mm) would probably perform identically.
02-18-2013, 12:12 PM - 1 Like   #4
Sagitta's Avatar
She has a Fujifilm belly tattoo, an X-Pro 1 breast tattoo and is holding a Fuji camera... I'm gonna guess maybe its a Fuji?
EDIT: And if its a Fuji X-pro 1 that was used, I'd guess it was the 60mm f/2.4 lens they have for it...
02-18-2013, 12:31 PM   #5
ivanvernon's Avatar
Visited your gallery and love your photos. Which Oest is the father and which is the son? I am curious what cues helped you to guess the lens used for this photo. ivan
02-18-2013, 02:04 PM   #6
Jamfke's Avatar
Each image has a link for EXIF data, but you have to log into those forums in order to see it.
02-18-2013, 02:10 PM   #7
boriscleto's Avatar
QuoteOriginally posted by ivanvernon Quote
Ole is the father and Adam is the son...
The camera used is a D700, a FF, 50mm is at the short end for a portrait lens and 85mm is a standard portrait lens.
02-18-2013, 02:22 PM   #8
Well those are two very common portrait lenses, and since it was a DX body I'm inclined to say the 50mm was used. The reason these lenses are often used for portraits is that they allow you to step a bit back from your subject, which minimizes perspective distortion. Plus, distortion is going to be low to begin with as the optical formulas are simple compared to those of ultra wide or ultra-tele lenses.
02-18-2013, 03:27 PM   #9
boriscleto's Avatar
Umm...the forum is labeled D700, not D7000...
02-18-2013, 08:08 PM   #10
QuoteOriginally posted by boriscleto Quote
Ah, then make it the 85mm!
02-19-2013, 03:56 AM   #11
kh1234567890's Avatar
The EXIF data is all there in the images, use ExifTool to read it. The answer is - it was a 70-200mm f/2.8 at between 150 and 200mm.
Code:
---- ExifTool ----
ExifTool Version Number : 9.18
---- File ----
File Name : 1361152979_LIM_2760.jpg
Directory : .
File Size : 1817 kB
File Modification Date/Time : 2013:02:19 10:52:55+00:00
File Access Date/Time : 2013:02:19 10:52:55+00:00
File Creation Date/Time : 2013:02:19 10:52:54+00:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Width : 1065
Image Height : 1600
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Colour Components : 3
Y Cb Cr Sub Sampling : YCbCr4:4:4 (1 1)
---- EXIF ----
Image Width : 2832
Image Height : 4256
Bits Per Sample : 16 16 16
Compression : Uncompressed
Photometric Interpretation : RGB
Make : NIKON CORPORATION
Camera Model Name : NIKON D700
Orientation : Horizontal (normal)
Samples Per Pixel : 3
X Resolution : 72
Y Resolution : 72
Planar Configuration : Chunky
Resolution Unit : inches
Software : andoWKS15
Modify Date : 2013:02:18 11:01:06
Exposure Time : 1/125
F Number : 2.8
Exposure Program : Manual
ISO : 200
Exif Version : 0230
Date/Time Original : 2012:04:27 15:30:17
Create Date : 2012:04:27 15:30:17
Shutter Speed Value : 1/125
Aperture Value : 2.8
Exposure Compensation : 0
Max Aperture Value : 2.8
Metering Mode : Multi-segment
Light Source : Unknown
Flash : On, Return detected
Focal Length : 200.0 mm
Sub Sec Time Original : 74
Sub Sec Time Digitised : 74
Colour Space : sRGB
Exif Image Width : 1065
Exif Image Height : 1600
Sensing Method : One-chip colour area
File Source : Digital Camera
Scene Type : Directly photographed
CFA Pattern : [Red,Green][Green,Blue]
Custom Rendered : Custom
Exposure Mode : Manual
White Balance : Auto
Digital Zoom Ratio : 1
Focal Length In 35mm Format : 200 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Subject Distance Range : Unknown
Serial Number : 2227324
Lens Info : 70-200mm f/2.8
Lens Model : 70.0-200.0 mm f/2.8
Compression : JPEG (old-style)
X Resolution : 72
Y Resolution : 72
Thumbnail Offset : 1050
Thumbnail Length : 7993
---- Composite ----
Aperture : 2.8
Image Size : 1065x1600
Scale Factor To 35 mm Equivalent: 1.0
Shutter Speed : 1/125
Create Date : 2012:04:27 15:30:17.74
Date/Time Original : 2012:04:27 15:30:17.74
Thumbnail Image : (Binary data 7993 bytes, use -b option to extract)
Circle Of Confusion : 0.030 mm
Field Of View : 10.3 deg
Focal Length : 200.0 mm (35 mm equivalent: 200.0 mm)
Hyperfocal Distance : 475.46 m
Light Value : 8.9
camera, lens, pentax help, photography, pictures
actual focal length of 55-300DA tibbitts Pentax SLR Lens Discussion 4 01-27-2013 01:27 PM
FoV, focal length and true aperture of lenses Ash Pentax SLR Lens Discussion 109 01-15-2013 01:05 PM
Is DOF at macro scales independent of focal length? top-quark Pentax SLR Lens Discussion 29 06-10-2012 05:37 PM
Pentax lens of similar focal length: vs faceoff comparisons required! JayR Pentax SLR Lens Discussion 12 10-31-2011 10:24 PM
What is the True Focal Length of your IF lens? Lowell Goudge Pentax SLR Lens Discussion 28 03-22-2011 04:04 PM
All times are GMT -7. The time now is 10:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
