02-22-2013, 12:36 PM   #1
Higher capacity K-r Battery?
Hi, has anyone tried a higher capacity D-Li109 battery and had problems with compatibility with the K-r?
I read that some K-r's get the mirror flop / slap issue with the OEM battery due to a possible voltage problem with it's firmware.
The OEM Battery is 1050mAh 7.4V and the battery I would like to get is an Opteka D-Li109 2000mAh 7.4V.
Does anyone know of any issuers with the higher capacity battery?
Thanks.
02-22-2013, 03:46 PM   #2
Na Horuk's Avatar
Does your camera have that problem? And I think I remember reports of people experiencing that problem with third party batteries as well. Though, not sure what their specs were.
Wow, just googled and got a result on amazon for a "Wasabi power battery", it specifically claims to be better than original Pentax battery and has a 77% discount lol
I wouldn't bother buying a different battery before actually experiencing the problem. On the other hand, if you want to have a second battery, go right ahead. I've had my K-r for some time now and no problems
02-22-2013, 03:56 PM   #3
paulh's Avatar
Would using an AA battery adapter and Sanyo Eneloops do better? I don't know how they compare with the OEM battery for reliability and how long they can hold a charge on the K-r. I do know they work very well with the K100D.
02-22-2013, 04:10 PM   #4
Thank you both for the replies.
What actually happened is the seller I bought from lost the original battery before sending the camera out and is offering to buy me a replacement since the battery was supposed to be included.
The 2000 and the 1050 are almost the same price and I'd like the higher capacity if it won't cause problems.
I haven't been able to see if it has the flop issue since I don't have a battery.
02-22-2013, 04:15 PM   #5
bigted's Avatar
I use generic replacements (I'm not sure they are anymore powerful) and they've been fine. I rotate between the original and the 2 generics I have. I've had my K-r since Sept 2011.
02-22-2013, 05:54 PM   #6
JimJohnson's Avatar
QuoteOriginally posted by CircaM Quote
Sent from Tapatalk 2.
Capacity is sort of immaterial. Voltage and maximum discharge rate are what counts. And I doubt that discharge rate will vary that much between two LiON batteries. All capacity means is the number of shots you can get off a battery.
I suspect the reason so many of us prefer eneloops AA batteries over LiON batteries is three fold...
#1- eneloops often have greater capacity (more shots per battery set)
#2- all rechargeable batteries can be recharged only so many times - eneloops can be recharged more times than the stock LiON before they are worn out.
#3- eneloops have a MUCH lower self-discharge rate. Turning this around, a LiON battery will lose more of its charge faster sitting in your camera bag or on the shelf than will eneloop batteries.
So far as I am concerned, the only advantage one LiON battery has over a set of 4 eneloop batteries is weight.
battery, camera, capacity, d-li109, k-r, oem, pentax help, photography
Ok crazy question regarding k10d battery vs. k-r battery dmbaile2 Pentax DSLR Discussion 2 08-05-2012 02:32 AM
K-R battery on Amazon Myke Pentax K-r 5 05-30-2011 05:12 PM
DIY for K-r battery Adaptor? Swapnil Pentax K-r 19 05-23-2011 07:37 AM
k-5 and k-r ISO noise higher than 3200? metungnasi Pentax K-5 14 12-11-2010 11:57 AM
Faster cards vs. higher capacity azcavalier Pentax Camera and Field Accessories 10 06-18-2008 07:36 AM
All times are GMT -7. The time now is 12:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
