Thanks all, that's very interesting. Particularly that nobody finds the image too dark. I look at
this and, yes the grey of the car may be the right grey, but
this just looks better balanced. (I don't know how to do this in Photoshop - I used FastStone's Viewer –
Adjust Lighting -> Shadows to bring up the dark background, then
Highlights to bring it back to balance). I suppose someone will now point out that the front wing of the car is now burnt out.
In the article referred to by anvh I did note :- “
Most digital cameras are better at reproducing low key scenes since they prevent any region from becoming so bright that it turns into solid white, regardless of how dark the rest of the image might become as a result.” Which is not immediately obvious, but is clearly common sense once it has been pointed out, and is almost certainly what is going on here.
That, however, leads me to the question – how do I do the equivalent of “
Adjust Shadows” in Photoshop? Adjust brightness and contrast don’t do it, adjust levels doesn’t do it. No idea……
