Thanks for the reply, Jamfke. My computer does have a built-in card reader. I've been looking for a way not to use it because one of the two SD cards I bought (for 60.00 each) failed almost immediately when I started inserting the cards directly into the computer. (When you put the card into the camera, it displays "Card not formatted" but resists all attempts to format it, so I guess it's toast). The second card, which I've always left in the camera, and used the wire connection to the computer, has been 100% reliable for over a year. So, I'm assuming that something about the process of removing and reinstalling the first card led to it's premature failure.
I called a Pentax service depot in Vancouver, inquiring about using one camera as a donor for the other.....either using the no-flash camera as a donor for the mini-USB jack in my original camera....or, using my original camera as a donor for the flash needed by the second camera. What I was told is that the cost of either repair exceeds the new replacement cost of another camera.
I think I'm going to have to buy another new camera. Given the issues I've had with them, I'd probably opt for a different brand, but because I've already got nine batteries, three chargers, and two travel cases for the Pentax, I'm likely going to have to buy another RS1000. If I have a third Optio RS1000 fail, it'll be my last Pentax product though.
Thanks for your answer and attempting to help.
