03-04-2013, 07:05 AM   #1
Help me make a decision
Hello Friends,
Looking for your support and advice .
My boss is going to the US for a few weeks . This is my chance to get a pentax.
I have made a selection based on a tight budget of 50k in and around .
Please help me make a choice or an alternative :
Selection 1 : From Adorama
Pentax K-5 Digital SLR Camera Body, 16.3MP CMOS Sensor, 1080p HD Video at 25 FPS, 3" LCD, Black 739$
USED Sigma 70-300 4/5.6 Apo Dg-mac F/pntx Af 99$
USED Pentax Smcp-a 50 F2 $30.00
USED Pentax Smcp-fa 28-80 3.5/5.6 *58/silver $60.00
Selection 2 : From Ebay
WHITE Pentax K-30 Digital SLR Body w/ 18-55mm & 55-300mm DA L 2 Lens Kit $869.99
If there is anything you want to comment or correct in my delection please help me out as I am new to this .
Regards,
Arka
03-04-2013, 07:57 AM   #2
mrNewt's Avatar
I'd go for the "Selection 1" ... and I'd do it fast before boss gets back
03-04-2013, 08:01 AM   #3
QuoteOriginally posted by mrNewt Quote
Thanks Mr NewT
Just a little concern as I am in India ...
Is the K-5 stable enough?
This is just to confirm because we have no service from pentax here ....
03-04-2013, 08:14 AM   #4
mrNewt's Avatar
QuoteOriginally posted by Arka Quote
Thanks Mr NewT
I have a K-5 and never had any issues with it to be honest ... is a very good and stable camera and if you take care of it, you should be able to enjoy it for years to come .
03-04-2013, 08:21 AM   #5
Thank you sir
03-04-2013, 11:54 AM   #6
Kozlok's Avatar
My only comment would be that you are missing any kind of wide lens. The DA 18-55 is plentiful and cheap, I'd advise picking one up, maybe instead of the 28-80. The 80mm end of that is covered by the 70-300, and the gap from 55 to 70 isn't large, so you don't need to fill it. The WR one is a few dollars more, but then you'd be sealed for the elements. Also, if you can manage just a little higher budget, the DA35 f2.4 is a cheap autofocus prime that you will find more useable than the 50. 50 is often too long indoors, and too short outdoors. If you are set on a cheap manual focus 50, though, the A is a fine one to start with. It was my first prime, and I have some wonderful pictures from it, but I quickly found I wanted it to be wider.
03-04-2013, 02:52 PM   #7
QuoteOriginally posted by Kozlok Quote
Thank you so much for the info Kozlok ....
Then i am left with 2 choices as an alternative to the 28 80
1. Sigma 18-35 3.5/4.5 F/kpr *82
2. Pentax Smc-dal 18-55 3.5/5.6 Al
Help me choose please.
03-04-2013, 04:31 PM   #8
Kozlok's Avatar
I don't own the sigma, but this thread indicates that the quality of the two are similar: https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/175583-sigma-18-35-3-5-4-5-a.html
Based on that, I'd get the Pentax for the larger range and newer coatings. I have the same lens, it is really a fine starter lens.
03-18-2013, 02:56 PM   #9
ok how about this....
Pentax SMCP-FA 28-80mm F3.5-5.6 --- New
vs
Pentax Smc-dal 18-55 3.5/5.6 Al used
i need quick answer for these please .... I need to make a decision by 20th
03-18-2013, 03:30 PM   #10
twitch's Avatar
Since you are buying a K-5 just buy it with the 18-55 kit lens. There is no such thing as a "new" FA 28-80 lens, it was discontinued years ago.
03-18-2013, 03:42 PM   #11
Thanks Twitch .... Any ideas how an E rating on Adorama is ...
03-18-2013, 04:02 PM   #12
twitch's Avatar
Adorama and B&H are excellent stores, actually they are the gold standard for photography stores.
03-18-2013, 05:42 PM - 1 Like   #13
Moderator PEG Judges
Kerrowdown's Avatar
You realise your making all of us an accessory before the fact and it's therefore going to be our fault when you get caught.
03-19-2013, 07:42 AM   #14
LOL .. sorry ... but so much obsessed and a little nervous ....
03-21-2013, 06:24 AM - 1 Like   #15
TER-OR's Avatar
You'll be fine, the K-5 is a performer. Learning to use it effectively should provide many hours of learning and entertainment. A two zoom lens kit with a nice manual lens as a learning platform is a great start. The Sigma longer zoom and kit lens will suit you for a while. When you find things you can't do with those, then look for something more special. Until then, get all the performance you can out of the lenses you're getting.
body, camera, pentax, pentax help, photography, selection, slr
Please help me make a choice. misbehave Pentax DSLR Discussion 24 07-09-2012 05:59 AM
limited lens decision to make nirVaan Pentax SLR Lens Discussion 21 03-22-2012 08:14 AM
Trying to make a 50-135 decision... FHPhotographer Pentax SLR Lens Discussion 10 12-09-2008 01:55 PM
Beginner buying K10D , need to make a budget lens decision hd28vsb Pentax SLR Lens Discussion 10 01-14-2008 09:53 PM
please help me make a lightsphere... slip Pentax Camera and Field Accessories 11 12-31-2006 05:18 AM
All times are GMT -7. The time now is 05:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
