03-06-2013, 05:05 PM   #1
D-AC50 ~ OK to leave Battery in?
After researching, I found that the D-AC50 should work with Pentax K-5. I've read numerous times that it wont charge a battery, but I've not read anywhere if it's OK to leave the battery in when the AC is plugged in. Can I leave the battery in while AC is also plugged in? Some devices can be damaged this way. The instructions that came with the D-AC50 don't cover this topic. Thank you!
03-07-2013, 09:00 AM   #2
Antanico's Avatar
QuoteOriginally posted by runintotherain Quote
Hello,
,The D-AC50 http://www.adorama.com/images/300x300/IPXKBC108.jpg is a compact AC rapid charger that replenishes the battery out of the camera. It exist since the time of the K10D.
As it is a rapid charger I would non leave it plugged with the battery all the time because it will continue to restart every time will query the battery status.
You could leave it plugged but be aware that is still using energy power... non a green behaviour.
Ciao
Ant
03-07-2013, 06:07 PM   #3
My D-AC50 is this:
PENTAX - AC Adapter Kit D-AC50
03-08-2013, 10:19 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
I would just plug in when I need to charge.
03-08-2013, 02:32 PM   #5
Ex Finn.'s Avatar
I would not leave it plugged in when not actually used as an external power source.
edit:" Can I leave the battery in while AC is also plugged in?". Absolutely, the battery is "bypassed" when the AC adapter is in use.
Last edited by Ex Finn.; 03-08-2013 at 02:42 PM. Reason: Failed to read and comprehend the original guestion.
03-10-2013, 11:14 AM   #6
Thanks Ex Finn.! It's working very nicely now w/ the battery left in. Also, it shows a little Plug instead of battery on the screen when it's plugged in, so it definitely detects the difference!
03-11-2013, 02:37 AM   #7
Antanico's Avatar
Hello,
I saw the other model (battery charger) so I add the link to the other picture in my reply.
Regards,
Ant
ac, battery, camera, d-ac50, pentax help, photography
D-AC50 power adapter cheap replacement Predictor Do-It-Yourself 32 07-05-2013 09:39 PM
Ok crazy question regarding k10d battery vs. k-r battery dmbaile2 Pentax DSLR Discussion 2 08-05-2012 02:32 AM
Hi, New k20D member D-AC50 snixnix Welcomes and Introductions 2 02-01-2012 03:33 PM
For Sale - Sold: D-LI50 Battery and D-BC50 Battery Charger (AUS/Worldwide) Ash Sold Items 4 03-28-2011 07:03 AM
OK to leave charger plugged in? starstuff Troubleshooting and Beginner Help 10 07-09-2009 12:20 AM
All times are GMT -7. The time now is 03:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
