03-06-2013, 10:20 PM   #1
Fixing scratches on LCD
Hey all, I have some pretty gnarly scratches on the LCD of my GX-10 (K10D) that I'd like to fix up. There are a couple of deepish scratches and then an area thats kinda foggy from a bunch of small abrasions. Is there anything that can be done for either one of those? I can post photos when I get home, although I'm not sure what I would take them with
03-06-2013, 11:15 PM   #2
Chaos_Realm's Avatar
QuoteOriginally posted by nixcamic Quote
couple of suggestions over here :https://www.pentaxforums.com/forums/pentax-dslr-discussion/60086-k100d-how-fi...lcd-cover.html
and another here: https://www.pentaxforums.com/forums/general-technical-troubleshooting/189833-...pentax-k7.html
03-06-2013, 11:15 PM   #3
Fixing deep scratches is difficult without turning the panel into a negative lens. Meantime, try this product that can be bought at many auto supply stores:
MeguiarsDirect.com:Clear Plastic Polish Clear Plastic Polish
I use Optex protective film on all my LCDs. It is thin but protects against scratches and can be peeled off easily when it becomes abraded and can be replaced. About $10.00 for enough for 2-3 bodies.
03-06-2013, 11:23 PM   #4
chromo's Avatar
Try using two mirrors and a long lens.
03-07-2013, 11:27 AM   #5
Moderator PEG Judges
Kerrowdown's Avatar
I guess a couple of aspirin if it's really bad.
03-07-2013, 12:47 PM   #6
mrNewt's Avatar
QuoteOriginally posted by RichA Quote
MeguiarsDirect.com:Clear Plastic Polish Clear Plastic Polish.
I would be very reluctant to use that on the camera ...
03-07-2013, 05:32 PM   #7
JimJohnson's Avatar
I had to stop and think if I would try this on my own camera, and decided, yes I would if I was bothered enough by the scratches. Every scratch fix I have seen works the same way... it doesn't fix the scratch, it removes material from either side of the scratch so it isn't as noticeable. 'Fogging' is really just a bunch of micro-scratches.
I have used the commercial automotive headlight de-fogging kits with great success - on polycarb headlight covers . You are abrading away most of the micro-scatches then top coating with a clear polymer.
And, I am a scuba diver. I purchased a used dive computer with a plastic cover over the LCD display that had some scratches. At another diver's suggestion, I used Brasso (yes the metal polish) to buff out all but the deepest scratches. It did substantially improve my ability to read the computer's display.
As they say, "Your Mileage May Vary". Again, how annoyed are you with how it looks now?
03-08-2013, 11:03 AM   #8
hman's Avatar
QuoteOriginally posted by JimJohnson Quote
I have used a tiny bit of toothpaste to remove scratches on watch crystals. The abrasive materials in the toothpaste do the trick. Have not tried on camera LCD though. Might work. At least it will smell nice and fresh!
03-08-2013, 01:17 PM   #9
To be honest, I wouldn't bother.
The camera is a tool to be used. It's not a piece of jewelry, or maybe it is?
03-08-2013, 10:13 PM   #10
kkoether's Avatar
QuoteOriginally posted by SOldBear Quote
Flitz Metal Polish!!! That is not the LCD that's scratched. It's a clear plastic cover over the LCD. Flitz can be had from Amazon.com or maybe a local boat dealer. It's great stuff with MANY uses.
03-09-2013, 08:05 PM   #11
The foggy bit is pretty annoying, I'm pretty used to it but I'm wanting to sell the camera since I'd like to upgrade and even though everything else works just peachy I feel the scratched LCD will ruin the resale. I'll try some toothpaste or brass polish, thanks all.
lcd, pentax help, scratches
Machinery Some macro work on my old used phone with it's dings and scratches photoleet Post Your Photos! 2 04-22-2012 06:34 PM
Micro scratches on offered Sigma 18-250mm oleolsen Troubleshooting and Beginner Help 6 09-04-2011 11:07 PM
Scratches on the K-5 limited? Ubuntu_user Pentax K-5 11 02-24-2011 09:43 AM
How to cure scratches on viefinder eyepiece? Vranx Pentax Film SLR Discussion 8 07-17-2010 01:00 AM
EEK Bayed!! "No Scratches" = Alot of Scratches?? rdrum76 Photographic Technique 28 11-29-2007 03:13 AM
All times are GMT -7. The time now is 12:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
