02-01-2014, 01:02 PM   #16
Rnovo's Avatar
QuoteOriginally posted by RockvilleBob Quote
You are correct - I use the term nodal point when it should be entrance pupil. When I next revice the chart I'll change the wording. I do cite the method of calculation in an earlier post in this same discussion on the forum.
Just looking to share date on lenses.
I just finished calibrating the Bower 8mm - I did get good results with the data listed.
If you have some lenses to add, please post - I will update the chart and change the wording.
On your 2 tables above should you not note the focal length for the DA* 10-17 at the 10mm setting for the distance you show as 57.80 or does it change as you go towards 17mm...?
The K5 tripod/flange shown is also valid for the K5IIs - it seems?
02-02-2014, 03:14 AM   #17
RockvilleBob's Avatar
QuoteOriginally posted by Rnovo Quote
I do not have the DA 10-17 lens.
My understanding is the the KII/KIIs both have the same body as the K5 and if that is the case then the flange distances would also be identical.
05-24-2014, 06:54 AM   #18
Today I found some time to determine the no parallax points of my lenses.
The set up used is a Really Right Stuff ball head and MPR-CL nodal slide.
05-24-2014, 07:30 AM   #19
Thanks for posting this
camera, information, lenses, measurements, pano, panoramas, pentax help, results, shooters
Focus Points for M lenses athlantar Pentax K-r 2 11-18-2012 10:24 AM
Nodal Slide options for 645D? Ryan Tischer Pentax Medium Format 4 04-11-2012 04:14 PM
Do my panoramas not look like panoramas? ftpaddict Post Your Photos! 22 04-21-2010 11:18 AM
Time for a Nodal Ninga? interested_observer Pentax Camera and Field Accessories 12 12-28-2009 09:23 AM
Nodal Points HGMonaro Pentax SLR Lens Discussion 3 06-06-2007 04:07 AM
All times are GMT -7. The time now is 06:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
