K-5 change in startup noise after fall
Hi all.
Thanks to my girlfriend's cat, who is the worst cat in the world, my K-5 took a little tumble after being stored in what was supposed to be a cat-proof closet. The startup noise (cycling of the aperture control motor) has changed in timbre, and now sounds a little more 'buzzy.' The aperture still works fine (lenses stop down without issue), but I'm concerned. Is there any possibility that there's a problem here that could be exacerbated by further use? I can't afford servicing at the moment, but I want to make sure that I'm not going to cause a minor problem to become major if I continue to use the camera.
Thanks!
