03-08-2013, 03:18 PM   #1
Firmware Update Issue on my K7
Hi new to the forum and i could use some help.
I just downloaded the latest firmware update for my K7 and can't seem to get the install working.
I have run the firmware exe to extract the readme and .bin file. Then I copied the .bin file to the root directory of a blank SDHC card.
I inserted the card in the camera and held the menu button will powering up the camera.
The current firmware version display on the lcd screen (ver. 1.02) but the update did not start ... the camera simply powered up as normal
The process seems pretty simple but I can't determine why the update does not start automatically
Any help would be most appreciated
03-08-2013, 04:12 PM   #2
QuoteOriginally posted by dec Quote
If you're using windows, sometimes dragging the file icon across, just creates a "shortcut" to the original file.
You may care to compare the sizes of the two files. Are they equal?
03-08-2013, 04:19 PM   #3
dec
Thanks Thingo .. actually I tried using the mac version at it worked oK problem solved.
camera, card, firmware, firmware update issue, help, k7, pentax help, update
Firmware update issue with ist D socrates Troubleshooting and Beginner Help 4 06-29-2013 04:21 PM
Can a firmware update really fix the AF issue???? tbirdas Pentax K-5 4 12-30-2010 01:10 AM
K7 Weird Behaviour after firmware update felixkh Pentax DSLR Discussion 5 04-07-2010 07:16 PM
K7 Firmware Update Workingdog Pentax DSLR Discussion 2 12-22-2009 01:53 PM
K7 new firmware update ... anyone knew? jpzk Pentax DSLR Discussion 4 12-18-2009 09:04 AM
All times are GMT -7. The time now is 01:52 PM. | See also: NikonForums.com, part of our network of photo forums!
