03-13-2013, 06:22 PM   #1
Pentax K30 with a AF-360FGZ flash question.
I want to use the external AF-360 flash in wireless mode as the single flash without the internal flash operating. The external AF-360 flashes only if the internal flash operates also. Is there a way to do it without using a sync cable? Eventually, i want to use two AF360 in wireless mode without the internal K30 flash operating. If I don't raise the internal flash, the external AF360 doesn't flash. what am I doing wrong or maybe it's not possible without a sync cable? Since the two external AF360 will be used in manual mode with different power range, I don't want the internal flash from interfering. Any help appreciated. Thanks.
03-13-2013, 06:40 PM   #2
aleonx3's Avatar
you have to have a master to trigger the slave flash. So, in this case, you can use the k-30 built in flash as master and the AF360 as slave. Further you can adjust of the flash output ratio between master and slave. If you don't use the internal flash as master, you can use a wireless flash trigger (such as catcus-5) to mount it on the hot-shoe, and wireless remotely control the AF360 mounted on another flash trigger as receiver.
03-13-2013, 06:47 PM - 1 Like   #3
Read this thread.
03-14-2013, 04:46 PM   #4
After reading the suggested threads above, I found the solution to my problem. It is very simple and works perfectly. All I had to do was set the internal flash mode in the menu to "control flash". When i took a picture with the internal flash only, it did flash but the picture was not at all affected because it flashed before tripping the shutter. Thanks to those of you who responded and to Warren who sold me a perfect AF-360FGZ for a nice price to use as my second slave.
03-14-2013, 05:05 PM   #5
QuoteOriginally posted by VE2CJW Quote
I'm glad it works for you.
But I'm curious: Have you tried taking a photo in front of a mirror, with the built-in flash visible in the mirror?
03-14-2013, 06:31 PM   #6
I took a photo in front of a mirror and can see the flash. But, I just took a photo in a dark location and the flash doesn't lighten the place at all, it is as if the flash never operated, The result is the same with or without flash, which is exactly what I was looking for. This morning, i met two friends who have Canon and Nikon cameras and their cameras have exactly the same feature as the Pentax but it is called something else. Now I'll start using my two slaves for some fun. Take care.
af-360, af-360fgz flash, af360, cable, flash, k30, mode, operating, pentax help, pentax k30, sync
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
For Sale - Sold: Pentax AF 360FGZ flash with Pentax Stand in good condition jjdgti Sold Items 5 03-31-2012 09:16 AM
For Sale - Sold: Pentax AF-360FGZ Flash (#1) doch4m Sold Items 4 02-18-2012 03:19 PM
For Sale - Sold: Pentax AF-360FGZ Flash (#2) doch4m Sold Items 2 02-18-2012 02:11 PM
For Sale - Sold: Pending - Flash AF-360FGZ with Case jfalcon7 Sold Items 3 11-14-2011 08:17 AM
All times are GMT -7. The time now is 07:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
